Are you using a regular ethernet patch cable? I had to use a crossover cable to get my Rio Receiver to connect to my WAP11. (I've never understood why a crossover is needed in some situations but not others. If someone reading knows why can you enlighten me?
I've got two WAP11's. One of them is an AP and the other is an AP client. If the problem is something other than needing to use a crossover cable we can compare our configs.
One thing you can do to isolate the problem is to have the WAP11 that is the AP client use DHCP over the wireless network to obtain an IP. If it's able to obtain an IP than you know that it is communicating with the AP. I would also suggest disabling WEP while you are trying to get this to work. The less variables the better.
-Dylan
