- Separate home/car memory for the left/right time alignment. I always want it centered at home, and only sometimes shifted in
the car. If flash space is an issue, perhaps an ;@AC force_center_delay=1 option or something.
Well, Happy Early Birthday. Have a
kernel on me. (modified HJ 233, also contains my preliminary bass/treble support)
[hijack]
;@AC lr_delay = 0
;@DC lr_delay = 42
-127 <= lr_delay <= 127
delay=lr_delay*0.1ms
Value is in tenths of ms - negative values mean right channel delayed, positive = left
config.ini value will overload the value in flash upon powerup, so values that get adjusted during use also get lost upon powerdown. I couldn't see an easy way to preserve user-set values in DC mode and use config.ini values in AC mode, which would have probably been ideal for the task.
Personally I think the 8 bits of flash used for storing this delay would be better donated to saving bass and treble levels....but I'm biased.)
I'm sure that Mark will find a better way to do this by next week than I could by April
