Incidentally, as Roger mentioned, if you run Emplode, Emplode will (by default) broadcast on port 8300 to find all Empegs "within reach". However, if you switch to unicast (i.e. just turn off broadcast in Emplode and specify the IP address of the Empeg), you'll be fine. Mike
