#78644 - 08/03/2002 11:57
Hijack v234: Happy Birthday, Tony
Okay, so his birthday isn't for another month or so, but I just couldn't wait that long.
Hijack v234 is out, and it will break your config:
all Hijack menu options need to be set up again.
Hijack now steals 16-bytes of flash instead of just 8
The left/right delaytime is stored separately for AC and DC power
The ButtonLED illumination setting is stored separately for AC and DC power
New "fake" button codes for remote-use and IR mappings: VolAdjOff, VolAdjLow, VolAdjMed, VolAdjHigh, and HijackMenu
The config.ini names have changed for the voladj parameters. The new names are the same as the new buttons: VolAdjLow, VolAdjMed, VolAdjHigh. You will get config errors if you have the old names in your config.ini
The voladj parameters can now also be set remotely, using /proc, FTP, and/or HTTP. Same syntax as config.ini
The built-in HTTP playlist browser now uses NODATA for it's Play buttons.
Some examples:
Turn VolAdj on (medium) remotely: http://empeg/?NODATA&BUTTON=VolAdjMed
Change VolAdj parameters remotely: http://empeg/?NODATA&VolAdjMed=0x2000,409,0x1000,27,70
That should be enough to get started with.
Happy (early) Birthday, Tony!
Re: Hijack v234: Happy Birthday, Tony
Laura
08/03/2002 14:12
Laura
08/03/2002 14:24
genixia
08/03/2002 14:38
rtundo
08/03/2002 15:18
fusto
08/03/2002 15:24
Laura
08/03/2002 20:30
Laura
08/03/2002 20:41
Laura
08/03/2002 20:56
Laura
08/03/2002 21:06
Laura
09/03/2002 13:40
Laura
09/03/2002 16:30
dcosta
10/03/2002 16:45
Laura
10/03/2002 14:37
Laura
10/03/2002 18:46
Laura
10/03/2002 18:59
redbutt2
10/03/2002 19:06
Laura
10/03/2002 19:24
Re: Hijack climbers
tms13
13/03/2002 09:54
Re: Hijack climbers
redbutt2
10/03/2002 19:04
crocklobster
11/03/2002 06:03
spider
10/03/2002 02:13
genixia
10/03/2002 06:25
bmiller
11/03/2002 18:00
bmiller
12/03/2002 09:17
