Um. I have the development version of 2.0-b11 and hijack (2.2.14-rmk5-np17-empeg50-hijack-v235) .. I just upgraded it since my hijack 223 wasn't letting me into shell either.
My empeg bootup:
empeg-car bootstrap v1.00 20000601 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux...................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v235 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Fri Mar 8 14:49:23 EST 2002
empeg-car player (hardware revision 7, serial number 90000839)
Command line: mem=12m
Calibrating delay loop... 208.08 BogoMIPS
Memory: 10912k/12M available (1008k code, 20k reserved, 344k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004e00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:47
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...ԕjչѕɽсɁѕɕ)5change_root: old root has d_count=1
Wѽչչсɽсokay
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To Comp
Starting player
hijack: removed menu entry: "Home/Work Location"
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Loading dancefile: "/empeg/lib/visuals/breakdance.raw"
Loading dancefile: "/empeg/lib/visuals/stonkdance.raw"
Loading dancefile: "/empeg/lib/visuals/princedance.raw"
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4054d000
! mp3_decoder.cpp :1049:Failed to find valid sync after seeking to offset 4429915, error=0xc0044000
Empeg Mk2 090000839 (BMW 330Ci E46 -02) http://guildhouse.net/BMW330Ci/
