No, Scott. The problem you're talking about was probably caused by the faceplate being screwed on too tightly. You can search the BBS for many posts about this issue, but some of the players coming out of Cambridge had one or two screws in a little bit too tight, causing a button or two to stick. The problem Empeg Ltd. is(was) working on recently is deeper into the electronic hardware.
Jason
_~= Dearing =~_
"WAY too happy about having #99."
_~= Dearing =~_
Gettin' back into it thanks to slimrio!
