I agree with Alan. You could put in ground isolating transformers or switches to separate the units. To test if it's a ground loop, try connecting [u]only[/u] the signal (center pin) of the RCAs to the Y cables and to the amp. This isn't a permanent fix but may point you in the right direction.
-- Murray I What part of 'no' don't you understand? Is it the 'N', or the 'Zero'?
