The problem is that the Microphone of Empeg must be managed by software.
You will have to code your own prog to have the Mic used by the Empeg.
For the phone, the best is to use an hand free kit that you hack.
You can replace the given microphone of the HFK by an other very good Microphone.
The status of the microphone is easily hackable with some modifications (feed the the mute line with a good signal)
The player (via Hijack buttons sequences), can switch to the Aux when the Mute line is On or Off.
And the sound of your phone can be done with explanations I gave before.
If you devellop a phone App, I'll be the first interested but It will be specific to your phone (Nokia XXXX or something else)
Empeg IIa - 10 Gb - Red Fascia - Tuner, the day is coming - I Will Strike From the Grey -
