For "higher quality", read "different manufacturer, different batch". We had a bad batch of one size of drive which has had a much higher failure rate than the others: we've switched manufacturer which will hopefully solve the problem. The new drives should be in the US later today (4th), so you'll get you unit back soon.
Hugo
