Are you on Windows 98? If so, you're in luck.
This is a bad idea if you want to pass the test. A+ was written before USB, winmodems with crazy IRQs and COM ports, and PnP network cards that can easily populate any IRQ. The test is counter-productive because everything you learn is dismissed once you work on new hardware or with a PnP OS.
