Remember that a blown fuse is a SYMPTOM, not a cause. It blew for a reason, and that reason will just come back eventually. It's important to find out what it was.
Make sure you don't defeat the fuse or put in a higher-rated fuse just to avoid the problem, or your player might be damaged.
