You can see on the Andrea site, but the connection to the empeg is just a 3.5mm mono jack. The unit has a thick wire with an RJ45 termination which goes to a DSP box: from here, there's a 3.5mm mono jack plug (to the empeg) and a 2-wire power feed (power from the empeg's amp control output).
Hugo
