I just got my antenna signal wired properly (lazy) and I have a problem where the antenna does not retract when the radio is shut off. The FAQ says:
Hugo discovered that some power antenna relays have a current draw problem and the voltage on the power antenna wire doesn't fall enough to make the antenna go down. If this is happening to you, try attaching a 1k resistor between the power antenna wire and ground and see if it solves the problem.
but that's not clear to me. I'm sure that it's enough information on its own, but I'm not entirely sure what to do with that information. Does it mean that I should attach a resistor to join the wire coming out of my tuner harness to the wire going to the antenna (I think not) or between where those two wires join and a ground, or does this all need to be done back at the antenna or what? (And I assume that should be a 1kOhm resistor.)
