Hijack v256 is now out.
The only new feature (that I know of, ) is that the infamous and erotic (to some) powerfully pulsating standby LED has been zapped. I'll replace it if many scream, but for the most part I suspect nobody will.
In it's place is a simple blink, once every ten seconds. The duration of the blink, and the interval between blinks, are adjustable in config.ini:
[hijack]
standbyLED_on=1 ;; in 1/100ths of a second
standbyLED_off=1000 ;; in 1/100ths of a second
It's not perfect. Even the default 1/100th sec blink is too bright for my liking, but to fix it would require a kernel thread running at real-time priority, so that finer resolution could be obtained. If somebody wants to hack one up for me, I'll look at it. Probably 30 lines of C or so.
