Is there a easy to use front end that uses LAME-similar to audiocatalyst? Im too lazy to encode all of my files one by one with a command line.
I actually wrote a front-end for the Fraunhofer command-line encoders that should work perfectly with any command-line encoder like LAME. I never tried adding a default command set for LAME (I never used LAME before), but you should be able to add whatever commands you need and it'll save it in its config file.
Of course, I'm not the only guy who wrote a cheap-ass front end for an encoder, there are a boatload of 'em out there. But if you wanna try mine, it's at my home page. It's called Jack the Ripper. Lemme know if you like it.
___________
