Greetings!
okay...
This sounds like either a mechanical problem with the brake button causing a short, the brake lights / sensors causing a short, or a loose power wire to the empeg loosing contact with the button press. Either way, the battery icon says the empeg is seeing voltage below its threshold (10v???). Something is causing a voltage drop at the botton press.
Check your wiring for anything loose that could be causing this. Look carefully at the wiring loom for a loose power wire, any connections you made, and especially anything running near your hand brake controls.
If you don't touch the hand brake, does it fully boot and function normally?
Paul Grzelak
