That is pretty damn cool. I have a couple questions for you if you don't mind..
1) What is the smallest object you can see in the air? Is the signal you get from the plane the result of radar or a transponder?
2) What happens if a plane strays from it's flight path, or an object is detected that has no flight path? I see you work for a private company. Do you share information with the government? For instance if you see a convoy of MiG's coming from the pacific, or you just found a ufo somewhere, do you contact the government or do y'all just mind your own business?
Edited by Yz33d (01/05/2002 01:51)
