Zeke
The client configuration is working smoothly and it's very easy to setup.
The setup-wizard in the SOHO3 includes the VPN-option. From there you can export a files with the settings you need in the client-software.
There is one importent thing that you must rember:
You can not have the same local IP-addresses in both ends on the VPN-connection (f.ex. 192.168.x.x). Since you cant always control the IP-address on the clients, and since most ADSL-routeres and cablemodems defaults to 192.168.x.x I recommend that you use 10.x.x.x range at the office behind the SOHO3
best regards
Ole
