I have a couple fo questions... appolgies if they've been asked before...
1) I know the player runs Linux (which is a lot more reliable than some OS's), but I was wondering what would happen if you were out on the road playing some tunes and the system crashes. Would you be stuck until you get home again? Is there a certain sequence of key presses to reboot the system and auto-login so you can start the music again? Some other contingency plan?
2) I read a post from Hugo (I think it was on /.) that said there wouldn't be a problem with the disk problems etc when you turn the ignition off, when you turn the ignition back on it would resume from the point you turned off... how? Is the system running permanently from the car battery?
Andy
- Given two theories.... pick the one that sounds funniest -
