pro equipment usually has a higher output level (in volts) than consumer gear. Pro gear is also more precise in it's circuitry which is why a pro DAT player can be tens of thousands of dollars whereas you might be able to get a consumer version for a couple of hundred dollars.
-- Murray I What part of 'no' don't you understand? Is it the 'N', or the 'Zero'?
