You rock, Hugo.
A config.ini option would be enough, although I'm starting to think that there might be a good use for an "advanced options" menu right there on the front panel to adjust stuff like this. Perhaps it could go in about the same place as the dimmer level control (wherever you end up putting that option).
___________
