Well, what that DID it! Thank you.
It never occurred to me to simply ignore the hard disk not found error, and just proceed with the upgrade (I used Beta11).
Any idea why the primary interface probe lists the Toshiba six times? Could this be indicative of a problem, just on the edge of not working...?
Note to FAQ/empeg folks: It would appear that some (only this model?) hard disks might appear to not work after disk builder alone. Proceeding to the upgrade process _anyway_ worked in my case.
Serial Log of Toshiba MK3017GAP as working single master is below..
Probing primary interface...
hda: TOSHIBA MK3017GAP, ATA DISK drive
hda: TOSHIBA MK3017GAP, 28615MB w/0kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:f
f
Partition check:
hda: [PTBL] [3876/240/63] hda1 < hda5 hda6 > hda2 hda3 hda4
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init player.cpp : 385:empeg-car 2.00-be
ta11 2002/02/08.
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
Toshiba as master, OEM Fujitsu as slave also works!
hdb: FUJITSU MHL2300AT, ATA DISK drive
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
f
Partition check:
ta11 2002/02/08.
! tunedb_disk.cpp :1224:Database size mismatch error.
Vcb: 0x4086d000
