I'm hoping you guys can help me ...
I use a notebook PC at home and at work. But, unlike most people, I don't work at the same building every day. Also, my work uses static IP's. So, everyday, after I boot up my machine, I have to reconfigure my IP, Gateway and Subnet and reboot. It is really getting annoying. A coworker suggested to me that I set up several hardware profiles, one for each building, so that when I boot up, I can select "Building 1" or "Building 2" and the machine would boot up with whatever IP I had assigned the last time I used that hardware profile. Well, it didn't work. It just uses the last IP assigned to the NIC, not to the hardware profile (unless I did something wrong).
Is there some program out there that can help me? I'm running Win2K Pro.
Brad B.
