Bad news for me tonight. I had my deck in my friends sled tongiht and the 3 amp fuse blew on the yellow wire off the cage.
After i got back to my car and got to test my empeg, i found out the the screen doesn't turn on anymore, and the led on the blinks like the unmodified led does. My led i set in hijack to blink every 10 seconds. Here is a copy of the bootup. What is wrong with my player?
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux....................................... done, booting the ker
nel.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v274 ([email protected]) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Thu Jun 6 19:37:21 EDT 2002
Processor: Intel StrongARM
empeg-car player (hardware revision 9, serial number 40104126)
Command line: mem=16m
Memory: 14952k/16M available (1040k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Found custom animation at offset 0x9b734
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004b00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: TOSHIBA MK3017GAP, ATA DISK drive
hda: TOSHIBA MK3017GAP, 28615MB w/0kB Cache, CHS=58140/16/63
empeg-flash driver initialize
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:1
e
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...hange_root: old root has d_count=1
Mounting proc
No secondary hard disk
Starting player
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Oliver mk1 30gb: 129 | mk2a 30gb: 040104126
