Sounds like we need ntpdate rather than a full xntpd implementation:
"ntpdate sets the local date and time by polling the Network Time Protocol (NTP) server(s) given as the server arguments to determine the correct time. It must be run as root on the local host. A number of samples are obtained from each of the servers specified and a subset of the NTP clock filter and selection algorithms are applied to select the best of these. Note that the accuracy and reliability of ntpdate depends on the number of servers, the number of polls each time it is run and the interval between runs.
ntpdate can be run manually as necessary to set the host clock, or it can be run from the host startup script to set the clock at boot time. This is useful in some cases to set the clock initially before starting the NTP daemon xntpd. It is also possible to run ntpdate from a cron script. However, it is important to note that ntpdate with contrived cron scripts is no substitute for the NTP daemon, which uses sophisticated algorithms to maximize accuracy and reliability while minimizing resource use. Finally, since ntpdate does not discipline the host clock frequency as does xntpd, the accuracy using ntpdate is limited.
Time adjustments are made by ntpdate in one of two ways. If ntpdate determines the clock is in error more than 0.5 second it will simply step the time by calling the system settimeofday() routine. If the error is less than 0.5 seconds, it will slew the time by calling the system adjtime() routine. The latter technique is less disruptive and more accurate when the error is small, and works quite well when ntpdate is run by cron every hour or two."
