I found this:
http://www.bit-tech.net/article/70/
Does something similar to what you want - I imagine if you wired this up, but instead wired the amp remote line up to the normally-closed relay outputs - it would switch from normally-closed to normally-open on powerup, and then after the delay, switch back to normally-closed, providing power.
Don't know if this helps, or even works.
A.
Empeg Mk2a 128G with amber lit buttons kit - #30102490
PhotoVancouver | Squamish, BC Webcam | Personal Website
