Actually I would say that EAC and LAME does not retain enough music information to make the music sound the way I want it to at the settings I used. At --alt-preset-standard, the files I produced were typically 4-5Mb in size whereas the MM files I produce are 5-8Mb in size...therefore to me, bigger file size = more music information = better sound. Audio compression means that some information is going to be lost during the process and as compression increases, even more information is dropped. As I stated above I have found that bass and treble are usually the first things to disappear as you lower the bitrate and listening becomes intolerable below 128kbps. I am the only one I've seen on this board who uses 100% VBR according to the various discussions I've read on this topic. Maybe if someone did a direct comparison of the two programs, would they notice a differance as well? I realize that everyone raves about EAC/LAME however, have they tried other rippers? Are they just being satisfied with what they hear figuring that it is quality because someone else told them it was? I think that it is really a subjective opinion based on an individual's own perception of quality.
When I first started ripping music (I have 40Gb now) I did exhaustive research to try and find the sound I was looking for so I would not have to re-rip my collection a second time. I have read so many posts here about people doing their collection again because they were not happy with their own results the first time around... You mention that I may have adjusted my EQ to compensate for an inferior compressor...well, I have no equalization in my home theatre set-up and my music sounds just fine to me. When I have friends over, most times they aren't even aware that it is compressed digital audio they are listening to, they always assume that it's my CD changer...so I imagine that I'm doing something right....
So I drop the gauntlet to you to listen to my system at the Cincinnati meet....and I'll even include the same songs encoded with both programs so you can compare for yourself.
01001010 01101111 01101000 01101110
