#103161 - 06/07/2002 03:00
IE popup blocker suggestions
Lately, my wife's internet surfing has started to generate more popups than ever. I was just going to tell her to make sure to close them as they come up (she normally doesn't even notice them because she runs IE maximized), but as I was doing so, I came across a number of those that won't allow you to close them (what was Microsoft thinking?). I was then going to try to switch her over to Mozilla, but getting her to learn a new program is like pulling teeth.
So, what can folks suggest to block popups for IE? I've tried Proxomitron, but it's default rules didn't seem to work too well, and I don't feel like spending hours or days fixing them. I just want something that works pretty much like Mozilla's [don't] Open Unrequested Windows.
Edit: Oh, and I don't want to pay any money for it. Maybe if it's exceptional in some way.
Edit again: I found one called `` Free Surfer'' that seems to work pretty well. Anyone have any thoughts on it? (Plus I fixed a misspelling in the Subject.)
Edited by wfaulk (06/07/2002 03:30)
#103162 - 06/07/2002 03:30
Re: IE popup clocker suggestions
What OS? If XP then there's a pop-up blocker in TweakXP that so far (a couple of days) seems to do a pretty good job...
#103163 - 06/07/2002 03:30
[Re: mtempsch]
Sorry. Win2K.
#103164 - 06/07/2002 08:44
I know it's probably a stretch, but I run a little software firewall called ZoneAlarm Pro (maybe you've heard of it). Anyway, the new version (3.0.1-something) has popup- and ad-blocker functions built in. If a popup manages to get through, which is rare - it disappears within seconds. Very happy with it.
#103165 - 06/07/2002 09:37
Re: IE popup blocker suggestions
Loc: Tucson, AZ
I've had decent luck with "pop up stopper". Iit's free, but they have better version for a fee. As far as closing the windows, "alt f4" dosen't work?
Steve
#103166 - 06/07/2002 10:04
Anonymous
Unregistered
Is this what you're talking about? (<--attached)
If so, I think it may be more of a bug in IE that can be taken advantage of and not an intentional feature.
EDIT: I just tried running the attached HTML in Mozilla and it crashed the browser, so don't click on the attachment unless you're using Internet Explorer.
101728-notitlebar.html (218 downloads)
Edited by Yz33d (06/07/2002 14:33)
#103167 - 06/07/2002 12:20
I have been trying several different popup-blocker packages, and each one so far has forced me to stop using it after a while because it had problems or limitations.
The one I am currently using and has worked fine so far (and hasn't forced me to stop using it yet) is called AdShield.
It is an IE plugin that is freeware. It is not a proxy (some of the other packages are proxies, which is a bit of a problem in certain configurations). Its advantage is that it doesn't globally blanket-kill all possible ads and popups, it only kills those that are kept in its internal list. This sounds like it would be a pain, but actually it's very convenient, because it doesn't automatically block certain popups that you would actually WANT to have. And it's really easy to maintain its internal list when you want to add one of your own.
Also, the developer is very "reachable" and I have exchanged emails directly with him. He's already working on fixing one minor cosmetic bug that I found.
There is a catch, though: It ships with an "empty" blocker list, which you must populate yourself. This is so that ad companies don't get mad at him and sue him for including their name in his list by default. If you decide to use this product, you can find pre-populated blocker lists elsewhere on the net, or I can send you mine.
The address for AdShield is http://www.adshield.org .
One final note: I installed AdShield on my wife's laptop. This is another indication that this is a good program, as I was never comfortable enough with the others to go that far with it. However, certain popups were still appearing on her PC, ones that weren't popping up on mine for the same sites. It turns out she had some other resident AdWare running (like Gator or CyDoor or something like that). So in addition to running AdShield on your wife's PC, make sure to use Ad-Aware ( http://www.lavasoftusa.com ) to scrub her PC clean of adware and spyware.
#103168 - 06/07/2002 12:31
Loc: Tucson, AZ
I'm going to try it. Sounds like this one is going in the right direction.
Steve
#103169 - 06/07/2002 12:50
[Re: lockuplever]
One of the things I like about AdShield is its ability to substring-block. For example, your blocker list can contain the strings /banners/ or /popup/, and any URL that contains either substring will go into the bit-bucket.
Of course, this creates the potential for having a blocker file that blocks "too much", but after a little tweaking, my blocker file is pretty much doing what I want it to do.
#103170 - 06/07/2002 13:32
Hey Tony, could you either tell me where i could get a pretty good list of known pop ups, or maybe give me your list? I installed AdShield and wanted to get a list going. Thanks.
This program reminds me of PopUp Killer, what a great program that, so convenient.
#103172 - 07/07/2002 05:37
[Re: ]
Yes, that is the type of window I'm talking about. However, in addition to your close window button, I can close it by bringing up the task manager, selecting that window and telling it to ``End Task''. The one on my wife's browser actually closed all of the IE windows when I did that, unlike yours.
BTW, Free Surfer successfully blocked that popup, but still allows the new windows from the url links on this forum. So far, I'm pretty happy with it.
#103173 - 07/07/2002 05:38
I'm not so much interested in blocking ads as I am in blocking popups. I know that 99.9% of all popups are going to be coming from those ads, so that would be a good solution, but Free Surfer seems to be working out for me so far. I'll let you know how it goes.
#103174 - 07/07/2002 07:28
Loc: Aarhus, Denmark
Hi Bitt
I use a program called POW which is freeware.
It can be found here: http://www.analogx.com/contents/download/network/pow.htm
There is also a lot of other interesting programs on that site..
Regards
Nicolai
#103175 - 07/07/2002 10:15
The problem is that a 100-percent solution to blocking all popups will also kill some popup windows that you don't want to have killed. There are certain sites that use popup windows legally and they are necessary for proper operation of the site. Which is why I like the way AdShield handles it. It kills most of the popups and lets me hand-edit its kill list, but the "good" popups don't get blocked.
I was using a 100-percent popup blocker that let you hold down CTRL to temporarily allow popups. It had nice features, but it was unstable and kept locking up my browser. So far, AdShield has been a lot more stable for me.
#103176 - 07/07/2002 20:42
Heh, for me it seemed that if I could just get rid of X10 and "World's largest casino" ads, I'd take care of 90% of my popups ![](/images/icons/smile.gif) Oh, and is it just me, or has X10 stopped showing up as much now?
By the way, I find that it's just as easy for me to simply use CTRL+W to close popups, but I'm probably going to try that adshield anyway.
#103177 - 07/07/2002 22:57
The nice thing about Mozilla's popup killer is that it's titled "Open unrequested windows" with a checkmark meaning that it's allowed. 95% of the legitimate sites open up popups correctly allowing them to still work while the ads/survey windows are always unrequested.
Anyone know of an IE blocker that can do this?
And also, a temporary way in Mozilla to reenable the above setting without resetting the preference? That 5ish% of the sites out there are annoyning with legitimate unregistered popups.
#103178 - 08/07/2002 04:46
[Re: drakino]
Loc: Virginia, USA
The best that I've used is PopUpCop. With no configuration needed it's very effective at blocking the advertisement pop ups while allowing most legitimate pop ups that are needed for site navigation. For the occasional site that doesn't work properly, it's easy to disable it altogether or add the domain to an "allow list". My experience is that it just works 99% of the time without having to fuss with it. You can also choose to disable all sorts of other web annoyances like background sounds and window resizing.
It's an IE plugin and not a proxy or seperate app that has to watch for window titles. The only downside is that it costs $20 but is well worth it, IMO.
-Dylan
#103179 - 08/07/2002 07:43
[Re: drakino]
It would seem that there are approximately as many solutions to this problem as there are users that want this problem solved. An interesting state of affairs. In some ways, I'm sorry I asked and then answered my own question, but maybe this will help someone else (or provide me more fodder when Free Surfer fails miserably for some reason).
Free Surfer does seem to be doing a good job so far, but, honestly, I use IE about 10% of the time, so I'm not the greatest source for a review on this. It seems to work very similarly to Mozilla's [Don't] Open Unrequested Windows option, as the links on this forum, for example, still open in new windows, while ad-type popups have been reduced to zero, so far, in my small sampling.
I can't think of a site that has legitimate unrequested popups. Give me an example and I'll see what Free Surfer does with it.
#103180 - 08/07/2002 07:58
I'll have to remember once next time I come across it, but most of the time it happens when clicking a link makes the browser change URLs and that new page tries to pop the window up. UInfortunatly it's bad webmaster design, and is identical to popup ads most of the time.
I have to admit that popup ads never crossed my mind back in 98 when playing with DHTML code in it's own popup window.
#103181 - 08/07/2002 08:28
[Re: Dylan]
I've been using WebWasher for years. It's a proxy server that has all kinds of HTML editing features, URL blacklists, cookie filters, image filters, and more. I've got it configured with a long list of sites along the lines of "ads.nytimes.com", and my web surfing experience is sublimely quiet and faster than normal. On the odd web page that's screwed up by WebWasher, you can click on the icon in the tray and it disables itself. This is mainly an issue for sites whose home page wants to run some fancy JavaScript then pop up the main window for you.
#103182 - 08/07/2002 09:17
CNN when you first go to their site will give you a popup to "select your edition" and save a cookie which tells them you want the U.S. version or the EU version or whatever. Try that (delete your CNN.com cookies if you want to give it a shot.)
Also, my local sports channel has a website (http://www.comcastsportsnet.com/) that does a similar thing. Try those two out.
#103184 - 08/07/2002 09:26
Or you could just accept the damn cookie.. But you mentioned before that you clear your cookies out a lot, so I guess the popup would be a bit of a pain.
Why can't these people figure out that popups have NO REDEEMING VALUE WHATSOEVER?
#103185 - 08/07/2002 11:58
[Re: tonyc]
Oddly, for some reason, my IE doesn't want to accept cookies. This problem has survived a complete Win2K reinstall. And both of those sites won't do the popup thingy without cookies being active.
Maybe someone can give me a pointer on the cookie thing, too. (It's not just settings in Internet Options. Though if I do try to allow all cookies always from everywhere, it just gets reset the next time I look.)
Edit: It actually just occurred to me that my cookie problem might actually have something to do with installing Microsoft's completely half-assed IPv6 implementation. But I really don't feel like uninstalling it just to test that assumption. It seldom makes any difference anyway, as it actually does accept cookies; it just seems to break some cookie testing methods.
Edited by wfaulk (08/07/2002 12:38)
#103186 - 08/07/2002 11:59
I think IE knows you're a Linux guy, and doesn't want to be nice to you.
#103187 - 08/07/2002 12:05
[Re: tonyc]
Well, now it knows....
Edit: And, to clarify the record, I prefer to think of myself as a Unix guy. Of the five computers I've got up and running here, only one of them is running Linux, and it's a Beige PowerMac G3. I've also got a Sparc machine running Solaris and an Intel machine running OpenBSD. I am trying to get a job so that I can purchase a new computer for the wife so that I can get back to running a somewhat real OS on my main machine again, though. If anyone wants to donate an SGI or HP or IBM or DEC machine, I am trying to round out my processor collection. And get the temperature in this room up another ten degrees.
Edited by wfaulk (08/07/2002 12:12)
#103188 - 10/07/2002 10:47
[Re: tonyc]
It definitely breaks both CNN and ComCastSportsNet. But it's easy to pause temporarily. Are you guys using something that wouldn't break this?
#103189 - 10/07/2002 11:06
That's one of the reasons I like AdShield. It doesn't break CNN until I tell it to break CNN by adding the correct string to its database. If I've used a pre-created database that includes the CNN popup, I can easily remove it.
#103190 - 10/07/2002 11:10
I had used PopUp Killer before, and it had some nice features including a thing that, when a popup first came up, allowed you to select whether it's a "good" or "bad" popup. So the CNN/Comcast ones could be easily added to the "these are okay" list (or, if you're Fabris, the "go the hell away" list.) But PopUp Killer also worked by reading titles/URL's of the popups, and that's far from ideal, and often it would bring my system to a crawl as it was trying to close the popups. So I got rid of it.
