#106813 - 23/07/2002 14:51 Question about audio quality through AUX
visuvius
Ok so heres the deal:
I have my Empeg Mk2a plugged into the auxilliary of my Kenwood Z828 head unit. The Kenwood in turn is hooked to a 2 channel Infinity Kappa amp. The Kenwood's volume goes upto 35 and the Empegs to +10 Overdrive or something like that.
Well anyhow, if i have the volume on the Kenwood at say, 22, and the volume on the Empeg at -13.5 dB, everything sounds nice and clean. But say i turn the volume on the Kenwood down to like, 12, and turn the Empeg's volume up, say to 0 dB or something (anything really), it'll sound like crap --just distorted and dirty. This is with the Eq's on both being set to Flat.
This doesn't really bother me or anything, as i just use the Kenwoods volume as the main control, but i'm wondering why it happens. maybe its a stupid question.
#106814 - 23/07/2002 14:53 Re: Question about audio quality through AUX [Re: visuvius]
If the Kenwood unit's input stage is only supposed to accept 1v inputs instead of 4v inputs, that would explain it. By turning the empeg down to -13db, you are doing the correct thing to compensate for plugging its 4v outputs into the Kenwood's 1v inputs.
#106815 - 23/07/2002 15:00 Re: Question about audio quality through AUX [Re: tfabris]
Speaking of which, does anyone know what the volume setting should be to ``precisely'' compensate for 1V inputs?
#106816 - 23/07/2002 15:15 Re: Question about audio quality through AUX [Re: wfaulk]
I think every line output is going to be a little different in level, and every line linput is going to be a little different in the level they'll accept before distortion. The 1v and 4v things are just an approximation.
