#107633 - 27/07/2002 10:02 Deleting files in a copied playlist...
redbutt2
Loc: San Diego, CA
Not sure this is a bug, but it is definately a useability issue. If you create a playlist, say "Pearl Jam" and add the album "Ten", then create another playlist, "Music I like", and copy "Ten" into it, if you delete tracks from "Ten" in the "Music I LIke" playlist, they will also be deleted from the original "Pearl Jam->Ten" playlist.
Shouldn't the playlists be separate?!
EDIT ... Oh yeah...this is with Beta13
Edited by redbutt2 (27/07/2002 10:03)
We need a bigger boat.
#107634 - 27/07/2002 11:18 Re: Deleting files in a copied playlist... [Re: redbutt2]
This is on purpose, by design. Please click here.
#107635 - 03/08/2002 07:57 Re: Deleting files in a copied playlist... [Re: tfabris]
redbutt2
Loc: San Diego, CA
That's why I said "not sure if this is a bug, but a useability issue". I disagree with the design choice here...I guess that is what I was trying to get across.
#107636 - 03/08/2002 13:42 Re: Deleting files in a copied playlist... [Re: redbutt2]
I'd disagree. If you copy the playlist, then you've got a link to the playlist, so that if that playlist changes, it changes everywhere it's referenced. If you want to make a duplicate of the playlist that's separate, you need to create a new playlist that contains the same songs.
Now, it's possible that there's a problem in that there's not an easy way to do that in emplode, especially with nested playlists, but, IIRC, jEmplode has a feature to do exactly that.
