#108227 - 29/07/2002 16:51 FAQ Update req'd?
AndrewT
Loc: Oxford, UK
Possibly the FAQ needs updating regarding How do I edit the 'config.ini' file on the player? now 2.0b13 has arrived?
In the FAQ it explains you should add a New DWORD value named allow_edit_config with a value of 1 to:
HKEY_CURRENT_USER
Software
SONICblue
emplode
2.0
Settings
With 2.0b13 you also now have to create the key Settings below 2.0 before you create the key allow_edit_config beneath it. This is not to be confused with the new key at a higher level named Settings - creating the sub-key allow_edit_config there doesn't work.
#108228 - 29/07/2002 16:56 Re: FAQ Update req'd? [Re: AndrewT]
If you mean that the last paragraph you wrote should be added, it already pretty much explicitly states that. If not, huh?
#108229 - 29/07/2002 17:01 Re: FAQ Update req'd? [Re: AndrewT]
Yeah, I don't see how...
"Note that this may require that you actually create the 2.0/Settings key. The key does not normally exist. Do not confuse this with the emplode/Settings key."
...could be any more clear?
#108230 - 29/07/2002 17:02 Re: FAQ Update req'd? [Re: tfabris]
Oh and to be absolutely clear, this behavior has not changed from 2.0b11.
#108231 - 29/07/2002 17:03 Re: FAQ Update req'd? [Re: wfaulk]
AndrewT
Loc: Oxford, UK
Uhhh, yeah. It appears my inability to read is causing spurious postings. Normal services will resume later. Do not adjust your set.
