#108528 - 31/07/2002 04:08 RCA plugs - photo wanted
CrackersMcCheese
Has anyone got a decent photo of how the RCA plugs at the rear of the Empeg connect to the mainboard?
#108529 - 31/07/2002 04:32 Re: RCA plugs - photo wanted [Re: CrackersMcCheese]
Erm, they are PCB mounted.. why?
#108530 - 31/07/2002 04:52 Re: RCA plugs - photo wanted [Re: rob]
CrackersMcCheese
i think one has come loose and if its simple, I can just solder it myself. A photo would be useful just so I know.
#108531 - 31/07/2002 06:31 Re: RCA plugs - photo wanted [Re: CrackersMcCheese]
David
Loc: Cambridge
If you are getting intermittent problems it can be caused by a thin track on the PCB that is prone to stress damage.
#108532 - 31/07/2002 07:14 Re: RCA plugs - photo wanted [Re: David]
CrackersMcCheese
Yeah, the RCA sockets are quite loose. Is this a major problem? Or just a bit of solder needed.
If I only use it in the car then I'll never need to fix it though, is that right?
#108533 - 31/07/2002 17:28 Re: RCA plugs - photo wanted [Re: CrackersMcCheese]
lastdan
Loc: santa cruz,ca
are the two RCA jacks on the unit 'live' when in DC mode?
#108534 - 31/07/2002 17:53 Re: RCA plugs - photo wanted [Re: lastdan]
Yes. And vice-versa.
#108535 - 01/08/2002 03:21 Re: RCA plugs - photo wanted [Re: CrackersMcCheese]
You do have a Mark 2/2a, right? On a Mark 1 the RCA sockets weren't PCB mounted and one did indeed come loose on mine eventually. I don't see how a Mark 2's sockets could come loose in a non-catastrophic situation.
Well, if it's a Mark 1, you don't want it (or its wires) to come off and start shorting against stuff.
#108536 - 01/08/2002 03:26 Re: RCA plugs - photo wanted [Re: peter]
CrackersMcCheese
Its a Mk IIa. I have a spare car mount so I'll just plug it in there and take the RCA leads off the mount into the hifi.
Its not worth me opening the player and soldering if its not going to pose a problem for the unit.
#108537 - 01/08/2002 03:59 Re: RCA plugs - photo wanted [Re: CrackersMcCheese]
That's not ideal as the car-mount RCA outputs are 4V (the car standard) whereas the "real" RCA outputs are 1V (the everywhere-else standard that your hifi will be expecting).
#108538 - 01/08/2002 04:10 Re: RCA plugs - photo wanted [Re: peter]
CrackersMcCheese
Right. Could this damage the empeg? Or would it just distort sound?
#108539 - 01/08/2002 05:24 Re: RCA plugs - photo wanted [Re: peter]
In fact it is often preferable to use the car outputs - most amps deal OK with the output level, which is more in line with most CD decks than the home outputs.
#108540 - 01/08/2002 09:34 Re: RCA plugs - photo wanted [Re: CrackersMcCheese]
mrfixit
Some old home cd players had a very high output compared to the ones today, but the sound was still fine... you just wont have to turn the volume on your stereo up as much.
Ben
hijacked
#108541 - 01/08/2002 14:29 Re: RCA plugs - photo wanted [Re: mrfixit]
maczrool
Loc: Louisiana, USA
Isn't it the voltage that determines the volume, not the current?
Stu
#108542 - 01/08/2002 17:11 Re: RCA plugs - photo wanted [Re: maczrool]
eternalsun
Loc: San Jose, CA
For a line-out yes, since it is used to modulate an amp.
Calvin
