#109043 - 02/08/2002 13:10 MP3 Decoder in Empeg
ma_145
Loc: NJ, USA
Does any one know which MP3 decoder is used in the Empeg player and can it be upgraded/replaced?
#109044 - 02/08/2002 13:11 Re: MP3 Decoder in Empeg [Re: ma_145]
Terminator
Loc: Dallas, TX
Its software based.
#109045 - 02/08/2002 13:14 Re: MP3 Decoder in Empeg [Re: ma_145]
In version 1.0 of the software, the decoder was the XAudio decoder.
In version 2.0 of the software, the decoder is (if I recall correctly) the ARM decoder.
In theory, you could replace the decoder with anything you wanted to code up and compile. The problem is that the actual PLAYER software is integrated with the decoder and is not open-source.
So. If you want to replace the decoder, you must also write your own full replacement for the player software, too. No one has done this for the empeg car player yet.
#109046 - 02/08/2002 13:22 Re: MP3 Decoder in Empeg [Re: tfabris]
You could replace the decoder without replacing the whole player software. With some clever code in the kernel you could intercept calls to the file system, allowing you to lie to the player when it reads the metadata (telling it that all the MP3 files are WAV files). Then you could intercept calls to load the MP3s from disk and decode them to WAV on the fly.
Not easy, but maybe easier than rewriting the whole player.
Anyway, I can't see any good reason to replace the decoder or the player software, both are excellent.
#109047 - 02/08/2002 15:16 Re: MP3 Decoder in Empeg [Re: andy]
Yeah there's certainly no point replacing the MP3 decoder - the ARM decoder is one of the best around.
#109048 - 02/08/2002 16:17 Re: MP3 Decoder in Empeg [Re: rob]
Would Rob be having a sudden attack of modest with regard to the player software ?
#109049 - 02/08/2002 17:23 Re: MP3 Decoder in Empeg [Re: andy]
Why? He didn't write the decoder.
#109050 - 02/08/2002 17:30 Re: MP3 Decoder in Empeg [Re: tfabris]
Hence my comment about his modesty (on behalf of the empeg team).
#109051 - 05/08/2002 11:37 Re: MP3 Decoder in Empeg [Re: andy]
ma_145
Loc: NJ, USA
Thanks guys. I was just checking to see if there were any updates to the decoder - since this can make a difference in sound quality. But since it already has one of the best out there, not need to update or change it.
