#111346 - 17/08/2002 05:01 Player Freezing up???
DBALKUNJR
Okay, I am running 2.0b13 and Hijack. My player has been freezing up on me both in the car and at home for the past two weeks. I have not had any problems to speak of up until then. I had taken the player apart to chaeck the integrity of the HDD cable connections. It seemed to help. I never got a a NO HDD FOUND messege at any time.
But this morning I got into work plugged it in and it started to stutter, screech, and hang. I unplugged it once and then put power to it and it was ok for about 10 minutes. Then it did the same thing. I removed power for about 20 minutes and then tried to apply power again. Now this time when it powered up I got a messege at boot up that ALL SETTINGS ARE LOST. I have never seen this messege before. Could this be a HDD cable or bad drive??? I scanned through the bug report forum and couldn't find anything that contained this messege. Can you help me out. The player should still be under warranty.
Dave
MK2 12Gb
MK2a 60Gb
#111347 - 17/08/2002 07:12 Re: Player Freezing up??? [Re: DBALKUNJR]
mrfixit
"stutter, screech" were these noises it made? If so I would say it's a bad drive.
Ben
hijacked
#111348 - 17/08/2002 07:27 Re: Player Freezing up??? [Re: mrfixit]
DBALKUNJR
Yeah, it is making those noises and getting hung up on certain sections of tracks that have played just fine in the past. It will be playing and all of a sudden it will just freeze and keep making the sound from that part of the track but very drawn out.
Dave
MK2 12Gb
MK2a 60Gb
#111349 - 17/08/2002 09:58 Re: Player Freezing up??? [Re: DBALKUNJR]
The "All settings are lost" means that its flash memory has been corrupted. All settings in flash memory just got erased.
#111350 - 17/08/2002 09:59 Re: Player Freezing up??? [Re: DBALKUNJR]
Have you done a RAM test on the player?
(Instructions in the FAQ under "Hyperterminal")
#111351 - 17/08/2002 10:52 Re: Player Freezing up??? [Re: tfabris]
DBALKUNJR
Tony,
I just did a test for RAM in Hyperterminal I have pasted the output below:
0000 empeg-car (issue9) board test version 0.05 <[email protected]>
0100 ram test starting
0110 testing ic 1 (0-15mb, low word)
0120 testing ic 2 (0-15mb, high word)
01f0 ram test done
0200 ide detect
0210 command issued
0212 drq=1 but irq=0 (no drive connected?)
0300 dsp/i2c test
03f0 dsp/i2c ok
0400 temperature detect
0410 temperature is 32
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
0600 ethernet detect
0610 ethernet rev 334b
06f0 ethernet ok
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
And here is the output from hyperterminal for boot up:
01f0 ram test done
0200 ide detect
0210 command issued
0300 dsp/i2c test
03f0 dsp/i2c ok
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
06f0 ethernet ok
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux....................................... done, booting the ker
nel.
Linux version 2.2.14-rmk5-np17-empeg51-hijack-v285 ([email protected]) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Fri Jul 26 11:13:49 EDT 2002
empeg-car player (hardware revision 9, serial number 10101980)
Command line: mem=16m
Memory: 14952k/16M available (1040k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004400).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: probing with STATUS(0x50) instead of ALTSTATUS(0xff)
hdb: IBM-DJSA-230, ATA DISK drive
hda: probing with STATUS(0x50) instead of ALTSTATUS(0xff)
hda: IBM-DJSA-230, ATA DISK drive
hda: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
hdb: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:07:b
c
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Press 'q' now to go into development mode. You Have Zero Seconds To Comp
þStarting player
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
Do you notice anything unusual?
It is funny, when I left work I put it in the car and it booted OK. Then about 2 minutes later it squealed and froze up again. then I pulled out the unit and reapplied power. It started to boot but got stuck on the logo screen. Now I am at home and it boos right up. I am very frustrated right now. I was hoping that I could get a hang while booting up so I could captureit in hyperterminal.
Dave
MK2 12Gb
MK2a 60Gb
#111352 - 17/08/2002 10:56 Re: Player Freezing up??? [Re: DBALKUNJR]
Well, it passed the RAM test but it certainly sounds like some kind of hardware problem. I'd contact support.
#111353 - 17/08/2002 11:07 Re: Player Freezing up??? [Re: tfabris]
mrfixit
But if he heard noises coming from the drive itself wouldn't that be a bad drive?
Ben
hijacked
#111354 - 17/08/2002 11:09 Re: Player Freezing up??? [Re: mrfixit]
Possibly. The screeching is odd, though. I guess it's conceivable that the screeching could be from a bad drive, just sounds strange to me.
#111355 - 17/08/2002 16:19 Re: Player Freezing up??? [Re: tfabris]
Could the screeching be bad data coming off the knackered drive, upsetting the decoder? I have a couple of mp3s that I've found make some absolutely horrible noises.
#111356 - 18/08/2002 18:51 Re: Player Freezing up??? [Re: tfabris]
DBALKUNJR
Today after my MK2 started to develop problems I decided to swap it's hard drive with the one from my Mk2A that this thread is about. This is what I did and the results:
1.) I have an extra HD cable so I tried to replace the old one and it still wouldn't boot up.
2.) I hooked up the drives from my MK2a on my MK2 and it booted from those drives and then ran it in my car all day and their were no shutdowns or freeze ups like I got when using the MK2A hardware with the same drives. This makes me think the problem does not lie in the hard drives or cables.
3.) I hooked up the 12Gb drive from my Mk2 to my Mk2a and when I powered it up the messege "NO HARD DRIVE FOUND CONTACT SUPPORT" came across the screen. this reinforces my thinking that there is a problem with the hardware not the drives or cables. this is only if the software is compatible from the MK2 to the MK2a.
I can not think of any other tests I can do. at this point except wait for support to contact me.
Dave
MK2 12Gb
MK2a 60Gb
