#116561 - 16/09/2002 08:28 Stereo separation
David
Loc: Cambridge
For those that are concerned about the stereo separation on early Mk 2 players (Rio-branded players are not affected), you can identify if you have the fault by visual inspection.
Open up the player and remove the drive tray (follow the guide in the drive upgrade article at riocar.org if you haven't done this before).
On the left of the mainboard is the DSP (it has a Philips logo on it). To the left of that is a small blue resistor pack. You want the resistor next to that, shown in the blurry picture below (finally the camera in my phone is useful for something!).
If it has '000' printed on it, you're ok. If it has '1000' or '100' printed on it, then you are affected and have the following options:
1. If you're competent with a soldering iron (that is, you've worked with SMT components before), remove the resistor and either bridge it over with solder or fit an 000 resistor.
2. Send the player in for repair. All affected players are out long since out of warranty, but I will carry out the repair free of charge, provided you pay for shipping.
#116562 - 16/09/2002 08:33 Re: Stereo separation [Re: David]
David
Loc: Cambridge
Again, with the resistor marked...
#116563 - 16/09/2002 09:36 Re: Stereo separation [Re: David]
Thank you very much for the great information.
I didn't know there was a such thing as a "0 ohm resistor". Interesting.
Can either you or Hugo explain exactly what one would expect to hear out of the player in this situation? Would a reduction of stereo separation be the only thing we'd expect to hear, or would there be other things we might notice? How much of a reduction in stereo separation would there be?
#116564 - 16/09/2002 10:01 Re: Stereo separation [Re: tfabris]
mtempsch
If you build by hand there's no trouble fitting a short piece of wire to bridge over another conductor, but pick-and-place robots used in automated assembly can't handle wire as easily as a component -> 0 Ohm resistors. They exist not only as SMT components, but as through-hole too...
#116565 - 16/09/2002 10:18 Re: Stereo separation [Re: mtempsch]
I figured that in that situation they'd just make a circuit trace there instead of a pair of pads.
#116566 - 16/09/2002 11:20 Re: Stereo separation [Re: David]
Okay, I've added an entry in the troubleshooting FAQ about this, basically paraphrasing what you said, and resizing your photograph. Let me know if the text needs any corrections.
#116567 - 16/09/2002 12:55 Re: Stereo separation [Re: David]
foxtrot_xray
Loc: Atlanta, Georgia
Yeah, usually called "Jumpers". Some thru-hole look like honest-to-gawd resistors ('cept they have ONE black line on them, for "0". Or, in the case of early 90's pinballs, white round ceramic looking things.
Of course, us techs called 'em "Wyre" (in a souther, hillbilly accent), because that's what we replaced them with if we ever had to adjust settings or some such junk. :> (In those earlier games, some reall-custom settings were enabled/disabled by use of those jumpers..)
Me.
#116568 - 16/09/2002 13:20 Re: Stereo separation [Re: tfabris]
The only difference is ~20dB difference in stereo separation. You can hear this on affected players if you play a track with full-scale on left and nothing on the right (and don't encode it as joint stereo!) and you can still faintly hear something on the right channel (and vice-versa).
You can't tell by fading using the balance control, as it doesn't do a full channel cut.
#116569 - 16/09/2002 13:25 Re: Stereo separation [Re: altman]
Thanks, I'll add that information to the FAQ entry.
#116570 - 20/09/2002 13:59 Re: Stereo separation [Re: David]
Okay, I did this on my player (the resistor on mine said "1000" when I looked) and have lived with it for a few days.
Because there's a circuit trace running beneath this resistor, I didn't want to take the chance of accidentally shorting it, so I left the "1000" resistor in place and just solder-bridged over the top of it (with the help of a small bit of wire). Only took a couple of minutes. The most time-consuming part of the job was disassembling and reassembling the player.
I did not perform any empirical tests either before or after the modification. I could have pumped it through SpectraLAB just for detailed info, but I didn't bother. I figured, regardless of any testing, I would be doing the mod anyway, so what's the point.
Now that it's done, I believe that I can hear a significant improvement in the overall sound of the player. It could just be my imagination, but it feels like there's more than just better stereo separation. The music just seems to have more presence and punch.
Has anyone else done this yet? Any comments on perceived improvement?
Thanks again, David and Hugo, for the information.
#116571 - 20/09/2002 15:01 Re: Stereo separation [Re: tfabris]
Double blind testing! Can't trust a plain before and after
- Trevor
#116572 - 20/09/2002 15:28 Re: Stereo separation [Re: tman]
Agreed. I will concede it might be my imagination.
#116573 - 23/09/2002 17:23 Re: Stereo separation [Re: tfabris]
Rezolution
Maybe instead of a wire, you could have installed a switch. Then you could flip the switch back and forth and see if it sounds better with the 1000 ohm resistance or with no resistance!
I just got another hard drive for my player so I will be checking the resistor later this week...
#116574 - 25/09/2002 21:17 Re: Stereo separation [Re: David]
David, do you know of the range of affected serial numbers for such units? I'd like to avoid having to open my Mk2 up if it's definitely too recent for the problem.
#116575 - 25/09/2002 21:36 Re: Stereo separation [Re: David]
Daria
I'm not affected, this this just proves again that you guys are the best.
Thanks.
#116576 - 25/09/2002 21:38 Re: Stereo separation [Re: Daria]
Ahh.. Dana Scully (as in X-files), rather than John Scully.. I was trying to figure out that T-shirt of yours..
#116577 - 25/09/2002 21:41 Re: Stereo separation [Re: mlord]
Daria
You didn't see the picture on the back?
Well, I guess I can tell you it looked like the image
here.
#116578 - 25/09/2002 21:56 Re: Stereo separation [Re: Daria]
Ahh.. thanks. And no, I never did see the back of the Tshirt, damnit!
#116579 - 25/09/2002 22:08 Re: Stereo separation [Re: mlord]
Daria
I couldn't risk turning my back on you?
Shrug. The 2001 Scully Marathon shirt didn't have anything on the back, and the picture was on the front. I think truthfully I like the 2001 shirt a bit better; I had one on the day before you got there.
Oddly only one person ever commented on the 2001 shirt (when I was flying to Sweden on like 9/22/01, as I boarded the flight to Arlanda at O'Hare) but lots of people wonder "What Would Scully Do?" and I have to turn around so they can see.
#116580 - 26/09/2002 04:15 Re: Stereo separation [Re: mlord]
David
Loc: Cambridge
Players with serial numbers beginning 06 are likely to be affected. We have also found 08 players with the problem, but I'm not sure how many of them are affected. I've not come across any 09 players with the fault.
#116581 - 26/09/2002 07:02 Re: Stereo separation [Re: David]
Okay, my Mk2 s/n 080000316 has a 1000-ohm resistor there, which I'll replace with a 0-Ohm wire shortly. Do you also have advice for the 18Khz rolloff fix? Hugo suggested removing two capacitors somewhere, but didn't specify which?
#116582 - 26/09/2002 12:55 Re: Stereo separation [Re: mlord]
belezeebub2
For clumsy people like me you can go and pick up a SILVER SOLDER pen it allows you to lay down condutive tracks with out soldering... I bet you could just draw a path over the resistor you were going to short across to fix the stereo seperation issue
#116583 - 26/09/2002 17:07 Re: Stereo separation [Re: mlord]
To improve the rolloff in earlier units, remove the two caps *right next to* the rear panel phonos (between signal & ground - they are unnecessary EMC measures). You should be able to tell which ones with a multimeter.
#116584 - 26/09/2002 17:45 Re: Stereo separation [Re: altman]
Are the caps not present at all in later units?
#116585 - 26/09/2002 18:12 Re: Stereo separation [Re: tfabris]
Are these the caps in question?
#116586 - 26/09/2002 18:30 Re: Stereo separation [Re: tfabris]
And... Since these caps are next to the home outputs, does that mean that the rolloff is only a problem on the home plugs (i.e., car plugs are not affected)?
Since I don't use the home outputs hardly ever any more, there'd be no sense in going to the trouble of making the fix if that were the case.
#116587 - 26/09/2002 19:25 Re: Stereo separation [Re: tfabris]
Yes, the 18KHz rolloff is only on the home RCA outputs (actually, I think Hugo said it's even worse than just 18KHz).
The Search function is your friend.
#116588 - 26/09/2002 23:37 Re: Stereo separation [Re: David]
Derek
Loc: NRW, Germany
I have an 08 player, and it has a 1000 ohm resistor in there. Am about to go and visit Rob Schofield today to fix it (his soldering iron is smaller than mine )
#116589 - 27/09/2002 04:56 Re: Stereo separation [Re: Derek]
I feel it is wrong to comment on the size of a man's tool, especially in a comparative manner...
#116590 - 27/09/2002 06:52 Re: Stereo separation [Re: pca]
schofiel
Thank you sir, it ain't what you've got, it's the way you use it that counts!
