#117909 - 25/09/2002 10:42 Dying or just minor problem?
misaochankun
Loc: South Florida, USA
10 gig unit, only one drive.
This is what I got after playing with it on the serial cable for a while:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315
(release)) #17 Wed Jul 24 18:23:20 BST 2002
empeg-car player (hardware revision 9, serial number 10101910)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004980).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:07:7
6
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
e000 v1.04
Copying kernel...
l.
empeg state support initialised 0089/88c1 (save to d0004a00).
6
hdb: probing with STATUS(0x00) instead of ALTSTATUS(0xff)
hda: probing with STATUS(0x50) instead of ALTSTATUS(0xff)
hda: IBM-DJSA-210, ATA DISK drive
hda: IBM-DJSA-210,
hda: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
6
Partition check:
Press Ctrl-A to enter pump...hda: status timeout: status=0xffBusy hda: drive not
ready for comm
ide0: reset timed-out, status=0xff
hda: status timeout: status=0xffBusy hda: drive not ready for command
hda: status timeout: status=0xffend_request: I/O error, dev 03:05 (hda), sector
2
EXT2-fs: unable to read superblock
e000 v1.04
Copying kernel...
l.
empeg state support initialised 0089/88c1 (save to d0004b80).
smc9194.c:v0.12 03/06/96 by Erik Stahlman (e
6
e000 v1.04
Copying kernel...
l.
empeg state support initialised 0089/88c1 (save to d0004c00).
6
Partition check:
Freeing unused kernel memory: 4k init player.cpp : 385:empeg-car 2.00-be
ta13 2002/07/24.
Vcb: 0x4086d000
endpoint stall(clear stall on ep5)
endpoint stall(clear stall on ep4)
S/N:010101910
#117910 - 25/09/2002 10:47 Re: Dying or just minor problem? [Re: misaochankun]
Aside from the "endpoint stall error", which is being discussed in a separate thread already, what is it in these boot logs, specifically, that's worrying you?
#117911 - 25/09/2002 10:53 Re: Dying or just minor problem? [Re: tfabris]
misaochankun
The many harddrive errors.
The first 2 or 3 boots it showed 'harddrive not found contact support'
After shaking the box and putting power back in, it booted up ok.
S/N:010101910
#117912 - 25/09/2002 11:04 Re: Dying or just minor problem? [Re: misaochankun]
OK, then please click here for the solution to that particular problem.
#117913 - 25/09/2002 11:23 Re: Dying or just minor problem? [Re: tfabris]
misaochankun
I have contacted (emailed) support and I am currently waiting for a reply. I was just hoping this was a minor problem and not one that requires sending it off.
S/N:010101910
