#11816 - 24/07/2000 19:19 Air holes on top of Empeg
doug316
Should I expect the Empeg to get some fresh air through the holes on the top of the case? Mine has a drive cable covering it from the inside. And man, when I pull the thing out of the dash it's HOT!
#11817 - 24/07/2000 20:31 Re: Air holes on top of Empeg [Re: doug316]
PaulWay
Loc: Canberra, Australia
My brother and I have been wondering this as well. I've been thinking of finding a way to mount a small fan to force cool air into the empeg unit, perhaps boring some holes into the case at other places to vent the hotter air (after first trying to ascertain where the motherboard etc, are... :-). Ideally I'd take the air feed from before the aircon, as living down here in Melbourne I'm more likely to be using heating than cooling. But we'll see.
I was driving down here (from Brisbane, over two days) and had one time where I'd put an old jumper over the empeg. About an hour after that it stuttered and froze, and I pulled it out to find it very warm indeed. I placed it in a slightly better ventilated spot and it was fine thereafter. I'm assuming that's the heat protection coming into play.
Save the whales. Feed the hungry. Free the mallocs.
#11818 - 25/07/2000 00:27 Re: Air holes on top of Empeg [Re: PaulWay]
The pattern in the top is suitable for mounting a small fan (low profile 40mm I think), though you will void your warranty doing this. The "motherboard" is the whole bottom of the case.
Actually, most heat comes from the display, which has a filament heater - this them gets dissipated in the metalwork. The actual main board generates very little heat, it's all in the display/drives.
#11819 - 25/07/2000 02:27 Re: Air holes on top of Empeg [Re: altman]
Scott
Loc: Connecticut, USA
While looking inside of my Mk1 I did notice a two pin connector on the motherboard for possibly the fan that you are talking about. Is it safe to connect a fan to this header?
Scott (00342)
Scott (00342)
#11820 - 25/07/2000 04:05 Re: Air holes on top of Empeg [Re: doug316]
Nah, those things are speed holes!
#11821 - 25/07/2000 05:14 Re: Air holes on top of Empeg [Re: rob]
Speedholes, eh? Maybe the old DiG-mobile could use some speedholes...
(good one rob)
DiGNAN
#11822 - 25/07/2000 05:14 Re: Air holes on top of Empeg [Re: PaulWay]
muzza
I Was actually going to punch a hole in the air system after the aircon but before the heating so that the emepg has cold air ALL the time. I have noticed problems when it overheats.
it would be a simple matter of siliconing a tube into the airway then having it attached onto the sled so that it sprays onto the top holes. Alternatively, a hole could be drilled in either side of the sled to pump air in the side vents. wouldnt have to be much.
Murray 06000047
____________________
#11823 - 25/07/2000 08:12 Re: Air holes on top of Empeg [Re: muzza]
Dearing
Loc: Florida
Yeah, I thought about doing this, too. Just put a vertical loop in the tube or something similar, to catch any condensation!
_~= Dearing =~_
_~= Dearing =~_
#11824 - 25/07/2000 09:20 Re: Air holes on top of Empeg [Re: muzza]
Yeah, but then in the winter you'd be spraying hot air onto the Empeg, and that's not good even if it's cold outside.
#11825 - 25/07/2000 11:10 Re: Air holes on top of Empeg [Re: Scott]
The 2 pin header is +12v from the accessory feed. Don't take a lot of current from it, and you will need to take ground from the case.
#11826 - 25/07/2000 14:03 Re: Air holes on top of Empeg [Re: altman]
muzza
hugo: The 2 pin header is +12v from the accessory feed.
wouldn't is be easier just to splice into the amp control feed and power a relay?
tony: Yeah, but then in the winter you'd be spraying hot air onto the Empeg
I'd try to take the air directly after the aircon. I usually have it on all the time anyway.
dearing: Just put a vertical loop in the tube or something similar, to catch any condensation!
yeah some kind of condensation trap, also a small lint filter in it somewhere.
Murray 06000047
#11827 - 25/07/2000 16:45 Re: Air holes on top of Empeg [Re: muzza]
The header was intended for an *internal* fan, if one ever became necessary.
