#119151 - 02/10/2002 22:50 Replay 4500 questions
I am considering getting a replay tv 4500 and have some questions.
Can I connect the PVR to the TV using composite or svideo. In the manual it appears you can.
Does replay have something similar to tivo's thumbs up and down feature where it will automatically record shows it thinks you would like.
Has anyone tried the remote on a sony 40XBR800 TV.
Any feedback would be great.
#119152 - 02/10/2002 22:57 Re: Replay 4500 questions [Re: msaeger]
Aw, darn, and I thought the last religion thread was finally dying out.
#119153 - 02/10/2002 23:10 Re: Replay 4500 questions [Re: tfabris]
robricc
Well, I worship my TiVo, but my POV has been stated so many times on this BBS already. Plus, these questions seem like he already made the decision.
#119154 - 03/10/2002 02:13 Re: Replay 4500 questions [Re: tfabris]
I don't care which one is better so don't tell me that. I don't want to start a holy war
I just want to know if it has these few features .
#119155 - 03/10/2002 05:46 Re: Replay 4500 questions [Re: robricc]
I already have the tivo but am thinking of getting the replay
#119156 - 03/10/2002 09:45 Re: Replay 4500 questions [Re: msaeger]
morrisdl
Loc: Rochester, NY USA
The Replay has both composite and svideo (and VGA output)
the closest thing to thumbs up in replay is theme based recordings. You select key words like ‘home’ or ‘Kournikova’ and it will automatically record any thing that has bob villa or Anna (without creating a record conflict).
I am guessing you are asking weather the replay remote can control the Sony TV - It controls the power and volume of my 36" Sony no problem.
Either Replay or Tivo - once you have one, there is no going back to live TV!!!
#119157 - 03/10/2002 12:08 Re: Replay 4500 questions [Re: morrisdl]
(and VGA output)
I did not need to know that... Considering my TV is a 27 inch VGA monitor right now...
Anyone know if Replay is ever going to make a Satelite version? Thats the one big thing stopping me from getting one. For now, my upgrade path is to a Dish 721 system, that mlord says is pretty hackable.
#119158 - 03/10/2002 18:02 Re: Replay 4500 questions [Re: msaeger]
Does the tivo2 still require a phone line or can I use broadband.
#119159 - 04/10/2002 05:14 Re: Replay 4500 questions [Re: drakino]
morrisdl
Doubtful – tivo has directtv locked up in a contract and Hughes makes their own version of a pvr.
Replay can control almost all sat receivers to change channels for recordings. It can interface though a serial connection or an ir blaster.
#119160 - 04/10/2002 06:19 Re: Replay 4500 questions [Re: msaeger]
robricc
You can use broadband as your only connection device with Tivo2. You just have to buy one of the supported USB ethernet cards. Tigerdirect.com has one for $4.99 that is supported, so it's not that big a deal that ethernet is not built on.
#119161 - 04/10/2002 07:34 Re: Replay 4500 questions [Re: robricc]
Can you tell me if there is a listing of supported usb to ethernet adaptors. Then I just have to put in "#401," for the phone number right ?
Also I can connect the tivo2 to my tv using svideo or standard video inputs right.
I am trying to find this info on the tivo community forum but there are many conflicting or confusing posts.
#119162 - 04/10/2002 08:01 Re: Replay 4500 questions [Re: msaeger]
robricc
Lines from the driver source below. All these should work:
PEGASUS_DEV( "3Com USB Ethernet 3C460B", VENDOR_3COM, 0x4601,
DEFAULT_GPIO_RESET | PEGASUS_II )
PEGASUS_DEV( "USB HPNA/Ethernet", VENDOR_ABOCOM, 0x110c,
DEFAULT_GPIO_RESET | PEGASUS_II | HAS_HOME_PNA )
PEGASUS_DEV( "USB HPNA/Ethernet", VENDOR_ABOCOM, 0x4104,
DEFAULT_GPIO_RESET | HAS_HOME_PNA )
PEGASUS_DEV( "USB HPNA/Ethernet", VENDOR_ABOCOM, 0x4004,
PEGASUS_DEV( "USB HPNA/Ethernet", VENDOR_ABOCOM, 0x4007,
PEGASUS_DEV( "USB 10/100 Fast Ethernet", VENDOR_ABOCOM, 0x4102,
PEGASUS_DEV( "USB 10/100 Fast Ethernet", VENDOR_ABOCOM, 0x4002,
DEFAULT_GPIO_RESET )
PEGASUS_DEV( "USB 10/100 Fast Ethernet", VENDOR_ABOCOM, 0x400b,
PEGASUS_DEV( "USB 10/100 Fast Ethernet", VENDOR_ABOCOM, 0x400c,
PEGASUS_DEV( "USB 10/100 Fast Ethernet", VENDOR_ABOCOM, 0xabc1,
PEGASUS_DEV( "USB 10/100 Fast Ethernet", VENDOR_ABOCOM, 0x200c,
PEGASUS_DEV( "Accton USB 10/100 Ethernet Adapter", VENDOR_ACCTON, 0x1046,
PEGASUS_DEV( "SpeedStream USB 10/100 Ethernet", VENDOR_ACCTON, 0x5046,
PEGASUS_DEV( "ADMtek ADM8511 \"Pegasus II\" USB Ethernet",
VENDOR_ADMTEK, 0x8511,
PEGASUS_DEV( "ADMtek AN986 \"Pegasus\" USB Ethernet (eval. board)",
VENDOR_ADMTEK, 0x0986,
PEGASUS_DEV( "Allied Telesyn Int. AT-USB100", VENDOR_ALLIEDTEL, 0xb100,
PEGASUS_DEV( "Belkin F5D5050 USB Ethernet", VENDOR_BELKIN, 0x0121,
PEGASUS_DEV( "Billionton USB-100", VENDOR_BILLIONTON, 0x0986,
PEGASUS_DEV( "Billionton USBLP-100", VENDOR_BILLIONTON, 0x0987,
PEGASUS_DEV( "iPAQ Networking 10/100 USB", VENDOR_COMPAQ, 0x8511,
PEGASUS_DEV( "Billionton USBEL-100", VENDOR_BILLIONTON, 0x0988,
PEGASUS_DEV( "Billionton USBE-100", VENDOR_BILLIONTON, 0x8511,
PEGASUS_DEV( "Corega FEter USB-TX", VENDOR_COREGA, 0x0004,
PEGASUS_DEV( "D-Link DSB-650TX", VENDOR_DLINK, 0x4001,
LINKSYS_GPIO_RESET )
PEGASUS_DEV( "D-Link DSB-650TX", VENDOR_DLINK, 0x4002,
PEGASUS_DEV( "D-Link DSB-650TX", VENDOR_DLINK, 0x4102,
LINKSYS_GPIO_RESET | PEGASUS_II )
PEGASUS_DEV( "D-Link DSB-650TX", VENDOR_DLINK, 0x400b,
PEGASUS_DEV( "D-Link DSB-650TX", VENDOR_DLINK, 0x200c,
PEGASUS_DEV( "D-Link DSB-650TX(PNA)", VENDOR_DLINK, 0x4003,
PEGASUS_DEV( "D-Link DSB-650", VENDOR_DLINK, 0xabc1,
PEGASUS_DEV( "Elsa Micolink USB2Ethernet", VENDOR_ELSA, 0x3000,
PEGASUS_DEV( "Hawking UF100 10/100 Ethernet", VENDOR_HAWKING, 0x400c,
PEGASUS_DEV( "IO DATA USB ET/TX", VENDOR_IODATA, 0x0904,
PEGASUS_DEV( "IO DATA USB ET/TX-S", VENDOR_IODATA, 0x0913,
PEGASUS_DEV( "Kingston KNU101TX Ethernet", VENDOR_KINGSTON, 0x000a,
DEFAULT_GPIO_RESET)
PEGASUS_DEV( "LANEED USB Ethernet LD-USB/TX", VENDOR_LANEED, 0x4002,
PEGASUS_DEV( "LANEED USB Ethernet LD-USB/TX", VENDOR_LANEED, 0x400b,
PEGASUS_DEV( "LANEED USB Ethernet LD-USB/T", VENDOR_LANEED, 0xabc1,
PEGASUS_DEV( "LANEED USB Ethernet LD-USB/TX", VENDOR_LANEED, 0x200c,
PEGASUS_DEV( "Linksys USB10TX", VENDOR_LINKSYS, 0x2202,
PEGASUS_DEV( "Linksys USB100TX", VENDOR_LINKSYS, 0x2203,
PEGASUS_DEV( "Linksys USB100TX", VENDOR_LINKSYS, 0x2204,
LINKSYS_GPIO_RESET | HAS_HOME_PNA )
PEGASUS_DEV( "Linksys USB Ethernet Adapter", VENDOR_LINKSYS, 0x2206,
PEGASUS_DEV( "Linksys USB USB10TX", VENDOR_LINKSYS, 0x400b,
PEGASUS_DEV( "Linksys USB10TX", VENDOR_LINKSYS, 0x200c,
PEGASUS_DEV( "MELCO/BUFFALO LUA-TX", VENDOR_MELCO, 0x0001,
PEGASUS_DEV( "MELCO/BUFFALO LUA-TX", VENDOR_MELCO, 0x0005,
PEGASUS_DEV( "MELCO/BUFFALO LUA2-TX", VENDOR_MELCO, 0x0009,
PEGASUS_DEV( "smartNIC 2 PnP Adapter", VENDOR_SMARTBRIDGES, 0x0003,
PEGASUS_DEV( "SMC 202 USB Ethernet", VENDOR_SMC, 0x0200,
PEGASUS_DEV( "SOHOware NUB100 Ethernet", VENDOR_SOHOWARE, 0x9100,
PEGASUS_DEV( "SpeedStream USB 10/100 Ethernet", VENDOR_SIEMENS, 0x1001,
You must enter ,#401 (take note of the comma) to use ethernet for your "daily call." Please note that ethernet is "unsupported," so there will be no documentation about it with your TiVo and TiVo help desk people will not answer questions about it. And yes, TiVo Series2 can output Composite and S-Video as well as RF (coaxial).
#119163 - 04/10/2002 09:32 Re: Replay 4500 questions [Re: robricc]
Thanks for the info I know the ethernet is an unsupported feature. Tivo should have the manual avaliable for download on their website that would help answer some questions too.
#119164 - 04/10/2002 14:39 Re: Replay 4500 questions [Re: robricc]
V99
Loc: Phoenix, AZ
You also need a DHCP server on your network somewhere for it to get an IP from, and you don't want it to have a routable one accessible to the outside world... A TiVo on a public IP is an exposed target for hacking or DOS attacks (although it's relatively safe because there's no servers running until you start getting into hacking the box).
#119165 - 04/10/2002 15:11 Re: Replay 4500 questions [Re: V99]
Thanks I have one of those linksys things that has a dhcp server.
