#123893 - 31/10/2002 16:45 X Server for XP?
AndrewT
Loc: Oxford, UK
Can anyone recommend an X Server that works on XP please? Preferably something with a 30-day eval. period or, even better, free
#123894 - 31/10/2002 16:51 Re: X Server for XP? [Re: AndrewT]
jaharkes
#123895 - 01/11/2002 02:46 Re: X Server for XP? [Re: jaharkes]
I used to use eXceed from Hummingbird. It was pretty good. Not cheap, though. You can get an eval copy from the page I linked to.
These days, I just use VNC, though.
#123896 - 01/11/2002 07:39 Re: X Server for XP? [Re: AndrewT]
XWin32
It has a 30-day full-feature eval period, after which it's still full-featured, but you can only run it for a few hours at a time, IIRC. I'm using it right now and the only problem I have with it is that I can't figure out how to start it without it asking me if I want to conncet via XDMCP or rshell. A cancel-click every once in a while isn't a big problem, though.
#123897 - 01/11/2002 15:58 Re: X Server for XP? [Re: Roger]
davec
Loc: Georgetown, TX USA
Doesn't VNC only have 256 colors available? I can run most vendors tools over VNC and work from home, but the important one won't because it requires more colors than VNC can provide. (Cadence Design Systems tools) I need Exceed for that, and that damn thing screws up my XP everytime I try to install it... Can't uninstall Exceed after that because it disables the RPC... Worked fine under 98 on version 6 I think it was.
Dave Clark Georgetown, Texas MK2A 42Gb - AnoFace - Smoke Lens - Dead Tuner - Sirius Radio on AUX
#123898 - 01/11/2002 16:14 Re: X Server for XP? [Re: davec]
VNC actually doesn't have a 256 color option as you'd think of it. It definitely supports more colors, and the low-color version has a static colormap (BGR233, IIRC). Progue around in your VNC client and you should find an option to select different color depths.
