#125000 - 06/11/2002 12:49 Save as HTML "complete": How to disable?
Okay, in IE6, when you hit "File/Save As..." it gives you the option to save a complete HTML mini-site on your hard disk that contains a subfolder of all the images. This is called "Save As Web Page Complete" or something like that.
The other option is to just save the HTML file without the extra stuff.
Sometimes one appears as the default, sometimes the other one appears as the default.
How do I make the plain-HTML save be the default all the time? Anyone know?
#125001 - 06/11/2002 12:55 Re: Save as HTML "complete": How to disable? [Re: tfabris]
Yes...that is an annoyance to me too...I'd love to know how to have it do html only all the time.
#125002 - 06/11/2002 13:21 Re: Save as HTML "complete": How to disable? [Re: tfabris]
Use wget.
#125003 - 06/11/2002 14:42 Re: Save as HTML "complete": How to disable? [Re: wfaulk]
Speaking of wget, I can never remember the utility that is in Mac OS X that does the same thing. Anyone else remember it?
#125004 - 06/11/2002 14:54 Re: Save as HTML "complete": How to disable? [Re: wfaulk]
Wget does not meet my needs at this time. I need to be able to use the Save As option in internet explorer, not a third party program that goes out to the web all by itself. Must be from within IE.
#125005 - 06/11/2002 15:03 Re: Save as HTML "complete": How to disable? [Re: drakino]
ricin
Loc: US: CA
That would be Curl.
[aeryn:~] root# curl --version
curl 7.7.2 (powerpc-apple-darwin6.0) libcurl 7.7.2 (OpenSSL 0.9.6b)
Donato
MkII/080000565
MkIIa/010101253
ricin.us
#125006 - 06/11/2002 22:38 Re: Save as HTML "complete": How to disable? [Re: ricin]
V99
Loc: Phoenix, AZ
You may want to add
alias wget 'curl -O '
to your .tcshrc file so you don't have to remember it.
#125007 - 07/11/2002 02:44 Re: Save as HTML "complete": How to disable? [Re: tfabris]
Click the "Edit in Notepad" button, and then save it from there?
#125008 - 07/11/2002 03:46 Re: Save as HTML "complete": How to disable? [Re: Roger]
Might work, I'll try that. Thanks.
#125009 - 07/11/2002 08:09 Re: Save as HTML "complete": How to disable? [Re: V99]
Bleargh. C Shell junkie! Figuring out how to change that was about the first thing I did on my MacOS X machine.
