#125471 - 10/11/2002 15:21 Lense ideas....
revlmwest
Loc: Hartsville, South Carolina for...
I've played around with these ideas for a while but to no avail. I thought I'd mention them here to see if anyone else will have a stroke of brilliance.
Problem: Because I drive a convertible, I use the smoked lense to make it as visible as possible in direct sunlight. However the amber lense matches my stock lights perfectly and looks much cooler, especially at night.
Possible answer #1- Some sort of quick release system on the facia so that changing lenses on a daily basis wasn't such a pain. I checked on pin style releasing bolts but none that I could find were small enough. I also thought about cutting lenses so that they sat on the screws and could be removed through the top of the facia with totally unscrewing the facia, but I dropped this idea early on.
Answer #2- A lense with a film that changes color in direct sunlight or due to tempature... much like sunglasses do.
Any thoughts....
Michael West
#125472 - 10/11/2002 16:00 Re: Lense ideas.... [Re: revlmwest]
matthew_k
Buy a seccond empeg?
#125473 - 10/11/2002 16:09 Re: Lense ideas.... [Re: matthew_k]
revlmwest
I knew someone was going to say this... . I would but if a second empeg is purchased it would go to my wife. So to fix my problem I'd have to but two more.
Michael West
#125474 - 10/11/2002 17:43 Re: Lense ideas.... [Re: revlmwest]
Greetings!
A sick thought.
How about getting an extra fascia from the empeg folks (if you ask nicely, they might have one for sale), gluing the lens and the fascia into a single piece (quicker swap) and replacing the front screws with some sort of ...
hmm... I don't know if they are made for this or what they are called, but I am thinking of a spring loaded clamp, similar to a small alligator clip that you would use for electronics testing...
#125475 - 10/11/2002 21:25 Re: Lense ideas.... [Re: revlmwest]
Better option:
Change your car's dash lighting to green.
#125476 - 11/11/2002 07:20 Re: Lense ideas.... [Re: tfabris]
The sunglasses idea is intruiging. Anyone know what that photosensitive film on them is called? Or where one could get some?
#125477 - 11/11/2002 07:48 Re: Lense ideas.... [Re: tfabris]
genixia
...and I managed to resist the temptation to suggest "Always drive with the top up."
Tony, you are encourageable.
#125478 - 11/11/2002 09:53 Re: Lense ideas.... [Re: genixia]
Incorrigible?
#125479 - 11/11/2002 09:54 Re: Lense ideas.... [Re: wfaulk]
You've been bitted.
#125480 - 11/11/2002 10:53 Re: Lense ideas.... [Re: wfaulk]
bodybag
Loc: Southern California
This is exacley why we need spel cheker for the bord. That wey, no bodi wood be imberasd or piked on wen thay make a speleng eror wile makeng a new post.
Bodybag - So Cal
Not a Whiner any more!!!
#125481 - 11/11/2002 13:35 Re: Lense ideas.... [Re: JBjorgen]
Terminator
Loc: Dallas, TX
The photosensitive pigments in transitions lenses react to the uv in sunlight. In cold temperatures, they will get very dark on sunny days. Most of the time the pigments are imbedded in the lens material, but a company called Beloptix has been coating the front of their lenses with a photochromic coating. Im not sure anything would be available much larger that 82mm. Maybe theres a non optical manufacturer utilizing the same idea for window panes??
Sean
#125482 - 11/11/2002 14:08 Re: Lense ideas.... [Re: wfaulk]
genixia
#125483 - 11/11/2002 14:22 Re: Lense ideas.... [Re: JBjorgen]
You've been bitted.
Bitten?
#125484 - 11/11/2002 14:30 Re: Lense ideas.... [Re: tonyc]
Once bitten, twice shy...
#125485 - 11/11/2002 14:58 Re: Lense ideas.... [Re: JBjorgen]
bodybag
Dude... a Mott the Hoople/Great White reference? Careful, you're showing your age.
Bodybag - So Cal
#125486 - 11/11/2002 16:05 Re: Lense ideas.... [Re: bodybag]
Dude, look up ieSpell. It is THE BUSINESS.
#125487 - 11/11/2002 16:10 Re: Lense ideas.... [Re: tfabris]
genixia
I'd rather accept the occassional embarrasment - it all adds to the humour of this place.
#125488 - 11/11/2002 16:57 Re: Lense ideas.... [Re: bodybag]
age 24....good music is timeless.
#125489 - 11/11/2002 16:57 Re: Lense ideas.... [Re: tfabris]
Unless they've improved it lately, no, it's not. The spell-check features in OmniWeb are. Spell-check-as-you-type is definitely the way to go.
#125490 - 11/11/2002 17:00 Re: Lense ideas.... [Re: JBjorgen]
I don't think I've ever heard the term ``good music'' applied to the band Great White before.
#125491 - 11/11/2002 17:06 Re: Lense ideas.... [Re: wfaulk]
Then again, they didn't write that track...it was a remake of the Ian Hunter (Mott the Hoople) original. (Although, the version on my empeg is Great White). I like it, so I guess that makes it "good" to me.
#125492 - 11/11/2002 19:04 Re: Lense ideas.... [Re: JBjorgen]
bodybag
The version on my Empeg is from Great White also (left over from my headbanging days). My admiration for Ian Hunter comes from his involvement with Gen X and the original punk movement anyway (oops... now I'm showing my age).
Bodybag - So Cal
#125493 - 11/11/2002 20:50 Re: Lense ideas.... [Re: revlmwest]
FireFox31
Loc: East Coast, USA
Rev, check my post in Projects.
FireFox31
#125494 - 11/11/2002 23:02 Re: Lense ideas.... [Re: wfaulk]
Agreed. I just wish I had my Mac laptop now so that I could run OmniWeb anywhere.
And unless I'm mistaken, the type as you go spell checking is actually part of the OS, and can easially be added to any application. I really hope Chimera adds it soon if this is indeed the case.
#125495 - 12/11/2002 07:46 Re: Lense ideas.... [Re: drakino]
Chimaera
Loc: DFW Area, Texas, US
<paranoid mode> Err, did I do something wrong??? </paranoid mode>
#125496 - 12/11/2002 10:30 Re: Lense ideas.... [Re: Chimaera]
Heh, no. I was talking about "Project Chimera", another Mac OS X only browser. Well, that is unless your one of the developers and are actively boycotting type as you go spell checking
#125497 - 12/11/2002 10:57 Re: Lense ideas.... [Re: drakino]
Chimaera
Well that's a relief then. I figured it wasn't me from the context and the slightly different name, but I figured I had better check.
And No, the browser is nothing to do with me, nothing I write runs on Mac OS X.
Mark.
20GB MKII 090000916
#125498 - 12/11/2002 14:36 Re: Lense ideas.... [Re: drakino]
True, but OmniWeb is the only browser I've seen support it. And I prefer it to Chimera, Navigator, etc. largely due to the fact that I'm running it on a toilet-seat iBook with only an 800x600 screen. It works way better at low resolutions than most of the other browsers do, plus it remembers window positions much better.
