Make that four...
I got mine on friday and it had the same symptoms as Alex
Except the last two lines of the boot-sequence are different; I only get rubbish :
empeg-car bootstrap v1.00 20000601 (
[email protected])
If there is anyone present who wants to upgrade the flash, let them
speak
now,
or forever hold their peace...it seems not. Let fly the Penguins of
Linux!
Copying kernel...
Calling linux kernel...
Uncompressing Linux.................................... done, booting
the
kernel
Linux version 2.2.14-rmk5-np17-empeg35 (
[email protected])
(gcc
vers
ion 2.95.2 19991024 (release)) #19 Fri Aug 4 15:58:47 BST 2000
empeg-car player (hardware revision 7, serial number 80000144)
Command line: mem=12m temp=28
Memory: 11000k/12M available (968k code, 20k reserved, 292k data, 8k
init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11
1999 )
Starting kswapd v 1.5
empeg display initialised.
empeg dspaudio driver initialized
empeg infra-red support initialised.
empeg state support initialised 0089/88c1 (save to d0005900).
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (
[email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC
00:02:d7:10:00:9
0
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter
pump...ԕсɽс٥)5oKY
MUѽչсɽс́)5
I have mailed
[email protected] but haven't received a reply yet.
I hope the solution is as simple as pushing back a cable...
Frank van Gestel
