#135569 - 16/01/2003 07:20 Remember tuner source in/out of car
jwtadmin
Loc: Ipswich, MA
OK so this has been happening for a long while at least since Beta 13. I have a tuner in my car but not one at work.
Under 12 my empeg would remember the last source it was playing in the car when it was returned to the car. i.e. tuner on: turn car off: power up at work no tuner: power off return to car: source is player not tuner.
___ John Turner "It's easier to ask for forgiveness than to ask for permission"
#135570 - 16/01/2003 09:09 Re: Remember tuner source in/out of car [Re: jwtadmin]
You don't have Hijack's "fake_tuner" option turned on, do you?
#135571 - 16/01/2003 10:30 Re: Remember tuner source in/out of car [Re: tonyc]
jwtadmin
Loc: Ipswich, MA
nope
#135572 - 16/01/2003 13:10 Re: Remember tuner source in/out of car [Re: jwtadmin]
That sounds like the correct behavior. What's it doing instead of that?
EDIT: Wait, you said "last source it was playing in the car", which is not correct.
The correct behavior is: If you take it inside, and it switched to "Player", then the next place you plug it in, it should be "Player", not tuner.
I don't think it EVER would go back to tuner if it was on "Player" in the house, even in beta 12. The only time it would stay on Tuner is if you pulled it out of the dash as "Tuner", it sat there not being plugged in, then you put it back into the dash and turned on the ignition. Only then would it go back to Tuner.
#135573 - 16/01/2003 13:42 Re: Remember tuner source in/out of car [Re: tfabris]
In other words, working as designed, huh?
#135574 - 16/01/2003 18:42 Re: Remember tuner source in/out of car [Re: tfabris]
jwtadmin
Loc: Ipswich, MA
If you say so, but up untill 13 I was enjoying a nice little bug.
Too bad....
I thought it was the correct behaviour. The player should remember what it was last doing for home and car use respectively
#135575 - 16/01/2003 20:16 Re: Remember tuner source in/out of car [Re: jwtadmin]
I guess I could be wrong about the way I'm remembering the past behavior.
