#137187 - 26/01/2003 11:47
Re: GPSApp Request: Spec location of routes
[Re: Daria]
#137188 - 26/01/2003 11:49
[Re: Daria]
I did explain that you needed to not run gpsapp from the kernel and run it either in a shell after telnetting in, or in a shell after connecting to the serial port.
sorry about that.
I'll try doing that now, see if it fixes the bug.
#137190 - 26/01/2003 11:53
[Re: Daria]
If it fixes the bug I will be sad.
It didn't.
Reason I tried is what Mark said about simultaneous reads of config.ini...
#137193 - 26/01/2003 12:06
[Re: Daria]
Arg, I can't right this instant. I'm in the middle of doing three things at once, and my serial port just started mucking up and I'd have to reboot the PC to get it to work again (it does this sometimes).
I will do it as soon as I can.
#137195 - 26/01/2003 12:12
[Re: Daria]
Is that built into hijack?
#137196 - 26/01/2003 12:17
Hijack v308
No, no telnetd (or remote SITE EXEC yet) in Hijack.
But v308 is out, and clears up any config.ini conflicts.
Note that at present, config.ini Hijack macros (;@HOME et al) work only for the player app, not for add-ons. I may "fix" this shortly, but for now that's how it works.
EDIT:
No, never mind.. I won't be fixing this. Add-on apps will have to do their own macro equivalents if they need them (dubious).
Edited by mlord (26/01/2003 12:18)
#137198 - 26/01/2003 12:25
Hijack v308 -- BUSTED
Never mind. .. v308 is fscked.
v309 shortly (ugh!)
#137199 - 26/01/2003 12:26
Re: Hijack v308 -- BUSTED
Yeah, I was gonna say... heh...
#137206 - 26/01/2003 12:46
[Re: Daria]
Ah, that's cool. For my house, the wiring is ad-hoc, whereever I can stuff a cat-5 cable from under the house, and I've cut cables on heating ducts before (sharp edges of aluminum plates etc).
#137207 - 26/01/2003 13:01
v309 shortly (ugh!)
Hmmmm. Been a while. Uncharacteristically.
I can picture the scene...
Mark's coding away, voice of Significant Other in the background: "MARK!!!! You still haven't taken out the garbage like you said you would!!!!"
"But I'm fixing Hijack!!!"
"NOW, MARK!!!!"
<Mark runs out and does the garbage>
"And what about the dishes?! You said you'd do those yesterday!!"
"But..."
"NOW!"
(Etc...)
#137208 - 26/01/2003 13:03
And note that I only say that because I'm procrastinating on doing the weekly garbage run myself right now.
(We live so far out in cow-country that we don't even have garbage service and have to actually run it to the dump ourselves.)
#137209 - 26/01/2003 13:06
No, wait, I've got a better one.
"Mister Mark Lord?"
"Yes, that's me."
"The government of Canada needs you for a top-secret project of utmost importance. The very planet itself is at stake. You're the only person with the skills necessary to do the job."
<20 minutes later>
"Wow, that was quick. Thanks!"
#137210 - 26/01/2003 13:10
Funny guys..
Okay, got it finally. My notebook is rebuilding it all now for you folks.
Should be about 5mins or so now.
#137211 - 26/01/2003 13:12
Actually, it was MUCH BETTER than taking out the garbage, though some people do call it "doing the dishes" or something similar when discussing in front of children..
#137212 - 26/01/2003 13:14
"MARK!!!! You still haven't rocked my world like you said you would!!!!"
#137213 - 26/01/2003 13:15
Or even better:
<20 minutes later>
#137214 - 26/01/2003 13:17
Hijack v309
Well, it was good for me, so I hope it's good for you, too!
