Page 9 of 10 < 1 2 ... 7 8 9 10 >
#139134 - 24/03/2003 14:32 Re: Home Dock Detection: how I'm doing it [Re: mlord]
For those of us (like me) who have other types of docking stations with tuners installed, I may eventually extend this test to look for a specific tuner-ID (that little rotary switch on the tuner module) when a real tuner is connected.
Okay, this has now been implemented, in parallel with the loopback test. Hijack v321, under the "Force AC/DC Power Mode" entry on the Hijack menu.
#139135 - 24/03/2003 20:45 Re: If you're one of the top 30, check the queue! [Re: mlord]
And more and more payment notices went out again today.. quite a few docks will soon be ready to ship.. putting this project *beyond* the midway point for docks shipped!
Also, a certain amount of list reordering has been done, to help clear out a pile of preassembled wiring for "Cool" docks.
#139136 - 29/03/2003 10:36 Re: If you're one of the top 30, check the queue! [Re: mlord]
Neurot
Have you considered making a digital out on there? or if i buy it with your current kit, would it be pretty easy to add the digital out later?
#139137 - 29/03/2003 15:15 Re: If you're one of the top 30, check the queue! [Re: Neurot]
At least two people are running the Digital out on the microphone pins of the docking connector. They then just add a mic jack to the rear of the dock (drill a small hole, and insert connector, with two wires running to pins on the docking connector.
How common are these?
#139138 - 29/03/2003 15:21 Re: If you're one of the top 30, check the queue! [Re: mlord]
maczrool
Loc: Louisiana, USA
Is there room for another RCA on the back? That's probably how I would do it, well that or BNC. No reason really to terminate it with a mic jack of any kind if there's room for a proper connector.
Stu
#139139 - 29/03/2003 15:28 Re: If you're one of the top 30, check the queue! [Re: maczrool]
Yes, there's room for even a couple more RCA jacks, or a BNC. Not too much depth on the inside for largish connectors which protrude internally, though, but most of them should fit fine.
If we were to standardize on something here, I could ship it prewired in the dock to those who ask for it. Cost would be a few bucks extra.
#139140 - 30/03/2003 09:57 Re: If you're one of the top 30, check the queue! [Re: mlord]
maczrool
Loc: Louisiana, USA
I could help standardize something if you like. I suppose RCA is the most commonly used for coaxial outputs, so you should probably use that. 75 ohm BNC is better, but larger and less compatible. I guess just a black or orange panel mount RCA would work fine.
So you would crimp a cable to a pair of contacts and install them in the mic in line postitions? It would probably be best to use 75 ohm coax or video cable between the contacts and the connector on the back of the dock, if that is what you are planning to do.
Stu
#139141 - 30/03/2003 11:42 Re: If you're one of the top 30, check the queue! [Re: maczrool]
SE_Sport_Driver
Let me know how this pans out... The only place I'd really get use out of a digital out board is the same place I'd use a docking station. What else would need to be done to the empeg? Just a standard digi out board?
ps - I'm more of a Toslink kinda guy, but I'll take what I can get. And I'm queued up in Mark's workshop at 40 or so, so we gotta move on this!
#139142 - 30/03/2003 13:33 Re: If you're one of the top 30, check the queue! [Re: SE_Sport_Driver]
maczrool
Loc: Louisiana, USA
Please see this thread for details on what is involved internally. Most of what I did is optional, but it makes it more reversable. You could skip the external connectors entirely and just route the signal through the Mic In lines. This would make it 100% reversable, ie. no holes in the Empeg case. Yes a standard coax board (DIG-C) would be fine here.
Coax is better anyway. If you have to have TOSlink, then just buy one of these.
Stu
#139143 - 31/03/2003 16:34 Re: If you're one of the top 30, check the queue! [Re: mlord]
Laura
Loc: Greenhills, Ohio
I just received mine today and it's very beautiful Mark. I was wondering how they might look stained? Everyone has mentioned painting but I kind of like the natural wood look if it would turn out decent.
Laura
MKI #017/90
whatever
#139144 - 31/03/2003 16:45 Re: If you're one of the top 30, check the queue! [Re: Laura]
I have two of mine that have just a blond shellac finish on them, and I like the look. You can do something very similar yourself. Just hit the home center and pick up a spraycan of clear polyurethane -- ask for the solvent-free stuff (mostly solvent-free).
Use masking tape to cover the rear connectors, and stuff some newspaper into the front opening to protect the docking connector, fan, etc..
Hang the dock with a string or small piece of wire through the side or rear holes, and spray on a nice LIGHT coat. Let it dry, and do it again.
After each spray session, turn the spraycan upside down, and press the nozzle for about 2 seconds -- this clears the spray nozzle so it doesn't gum up and waste the rest of the can.
You probably knew most/all of that, but..
#139145 - 31/03/2003 17:00 Re: If you're one of the top 30, check the queue! [Re: mlord]
Laura
No I didn't, so thanks. I may try that myself.
If you are ever ready to tackle making a MKl box, let me know
Laura
MKI #017/90
whatever
#139146 - 31/03/2003 18:02 Re: If you're one of the top 30, check the queue! [Re: mlord]
SE_Sport_Driver
Mark, can you post a pic of the final product?
#139147 - 31/03/2003 18:09 Re: If you're one of the top 30, check the queue! [Re: SE_Sport_Driver]
It looks just like dock #001, as pictured on the web site http://rtr.ca/docks/
The only changes since then have been mostly internal, though the dock is about 1/64" narrower now, and about 1/16" shorter in height. No photo would show that, though.
Well, usually like #001. Because there are two varieties of MDF being used in the shop right now, some docks have a "two-tone" appearance, with slightly lighter coloured side panels, and darker tops/bottoms. But those few from the "transition period" (between MDF stocks) are pretty much all out there now. New ones are mostly being made from the lighter colour MDF stock now.
When I run out of the current stock, I'll be getting the darker MDF again for one final run of docks -- I recently found a place 20Km from here that still carries the darker stuff.
#139148 - 02/04/2003 02:14 Re: For Sale: Home/Office Docking Stations!! [Re: mlord]
303
Loc: Germany
thank you very mutch!
i just got it.
what a well done product.
everybody should have one!!!
cheers Tim 303
#139149 - 03/04/2003 09:07 USA Style mini AC Adaptors for docks [Re: mlord]
[copied from the General thread]
Thanks to some horse trading with Rob, I now have a limited supply of the original RioCar USA-style 120VAC power adaptors (the ultra-small ones!) for sale along with the Docking Stations.
Anyone who purchases a docking station, can opt to have a new AC adaptor (power supply) shipped along with it for US$11 extra, S&H included. EDIT: Or more than one, if you like, at US$11 each.
This is only for new dock shipments, so if you want a power supply, just sign up for another dock!
To reserve a power supply for your dock, email me at [email protected]
I will NOT respond to your email. Instead, I will just make a note on your dock order, which you can verify by viewing the status page with your email address: http://rtr.ca/docks/
Edited by mlord (03/04/2003 09:08)
#139150 - 03/04/2003 20:38 Re: For Sale: Home/Office Docking Stations!! [Re: mlord]
Micman2b
Loc: Central, NC, USA
Mark,
Thanks for the hard work and design on these sleds. Pretty slick. And the fan is whisper quiet...
I really like that Empeg self detects that the unit is at home, even though it is using the rear connector for power... Again Pretty slick...
_____________
Sean in NC
130gb MK2a w/ 32mb ram
80gb MK2a empeg spare
#139151 - 11/04/2003 15:13 Re: For Sale: Home/Office Docking Stations!! [Re: 303]
lothar
Here's a quick poll...
How long has it taken for your dock to arrive?
I'm still waiting patiently for mine... shipped on March 27th... today is April 11th, which is 15 regular days or 11 business days later and it still isn't here!
According to canadapost.com, the delivery time is 6 to 9 business days. On Mark's tracking website it says 5-10 days.
#139152 - 11/04/2003 16:40 Re: For Sale: Home/Office Docking Stations!! [Re: lothar]
skibum
Loc: Swindon, UK
still waiting for mine, but hey, I'm in South Africa, the only thing you get quickly here is aids.
I'm hoping mine arrived before 15th May, which is when I depart back for the UK. Although if it doesn't it's not that much of a problem, as it just means a friend will have to forward it on to me.
From what those who have received have said, it's going to be a wonderful day when it arrives (even if I have ordered 2 more to go to the UK).
I think Mark should start signing the remaining docks as he sends them out, as they are works of art (well he can sign mine if he wants).
#139153 - 11/04/2003 16:44 Re: For Sale: Home/Office Docking Stations!! [Re: lothar]
Chuck
It's gonna depend on where you live. I'm in Texas and it took 15 business days.
-Chuck
#139154 - 11/04/2003 19:37 Re: For Sale: Home/Office Docking Stations!! [Re: lothar]
Now remember rednecks, y'all are at warr rat naw! Sah thangs is guna be slowere then thay mayght normallys be. Y'heeere?
#139155 - 11/04/2003 19:38 Re: For Sale: Home/Office Docking Stations!! [Re: mlord]
And for the humour impaired, the point is that, with the current threat levels against the USA, packages crossing their borders are taking a little longer than normal these days.
#139156 - 11/04/2003 20:18 Re: For Sale: Home/Office Docking Stations!! [Re: mlord]
lothar
I never knew you canucks had the redneck lingo in you, "a"?
From the sounds of it, I'm sure it will be well worth the wait and anticipation.
#139157 - 14/04/2003 13:52 Re: For Sale: Home/Office Docking Stations!! [Re: mlord]
fede
Loc: Texas
effen ah dud n no budder. ah wud tank yu wuz makn fun uf us her en Texas.
'a stock car stereo is a beautiful thing to waste' MKIIa 60gb MKIIa 20gb
#139158 - 14/04/2003 13:59 Re: For Sale: Home/Office Docking Stations!! [Re: Chuck]
lothar
Quoting the great Christopher Walkin from a recent SNL appearance, "wow. wowee wow wow".
My docks arrived today (12 business days after shipment). I must compliment Lord on the superiour crafstmanship and manufacturing. This guy definately knows his tools.
Now to figure out if what finish will compliment best...
-lothar
#139159 - 14/04/2003 14:05 Re: For Sale: Home/Office Docking Stations!! [Re: fede]
wau? yoose fokes sveeks phunnie doun thar two?
#139160 - 02/05/2003 09:12 Re: For Sale: Home/Office Docking Stations!! [Re: mlord]
jbauer
Loc: San Francisco, CA
Add me to another happy customer. Got my dock today and it's beautiful. Now I need to stain it cherry...
- Jon
#139161 - 02/05/2003 09:38 Re: For Sale: Home/Office Docking Stations!! [Re: jbauer]
Excellent!
I am fast running out of the pre-milled wood parts, and will soon have to get more MDF and hardboard to run the final batch of 100 more docks.
The wiring and hardware stuff is trickling in, and SWMBO is busy crimping wires now for them.
I think there'll be a lull in shipments for a week or two while we get the next batch through the pipeline, after which thinks should start moving again at a good pace..
Cheers all!
#139162 - 02/05/2003 09:42 Re: For Sale: Home/Office Docking Stations!! [Re: mlord]
Happy Birthday tonyc
100 more docks? Does that mean there's room at the end of the current queue? About how many of those 100 aren't accounted for by current orders?
#139163 - 02/05/2003 09:49 Re: For Sale: Home/Office Docking Stations!! [Re: tonyc]
There's about 20 sets of dock components that are as yet unclaimed by anyone.
