#139044 - 14/02/2003 10:12
Re: dock
[Re: qbasic309]
Run the string in a loop through two of the ventilation holes on the back, and knot them well above the docking station. This way, you can suspend the dock from the rear, and the only contact the string will make on the dock would be along the opening of the air holes.
#139045 - 14/02/2003 12:12
Re: dock
[Re: qbasic309]
Loc: Hartsville, South Carolina for...
I'm not sure what Mark had in mind, but you could just bring the string in the vent hole and then tie it something larger than the vent hole, a pencil, an old stick of ram....
Michael West
#139046 - 18/02/2003 18:48
Re: Status Update
Well, there are a total of 71 dock orders so far (not including my own!), and seven of them have been shipped out so far.
Based on the enthusiastic responses, I have decided to make at least 75 of these now -- I have purchased sufficient quantity of most of the parts for that many, excluding the docking connectors, which I will re-order once my remaining stock of them is used up (about 43 left).
Production is crawling along -- in the workshop there are about 90 sets of wooden blanks now cut to size, and machining has begun on those. I have also purchased a proper crimping tool to speed wiring of the docking connector pins -- no more soldering on the connector ends of the wires.
I'm busy with a Linux contract (and tuner assembling) this week and next, but by mid-March the docks should be rolling through the post office again.
#139047 - 20/02/2003 11:22
Re: Status Update
Got my dock last night. Wow Mark. The pictures don't do the details justice... you put a ludicrous amount of thought and detail into the design man. I'm very impressed. It's well worth the $ if anyone is on the line. I just hooked it up here at the office... perfect! No more scrambling with cables dropping behind the desk and having a mass of wires on my desk.
I can't wait to get it painted.
Thanks again for your efforts Mark. This dock kicks ass.
#139048 - 20/02/2003 11:30
Re: Status Update
I keep meaning to ask: is there any facility for attaching a security cable? I'd be fine trailing one through a hole in the back of the dock, but I really need security at the office. I'm in an office with, I'd guess, 1500 people (gub'mint), and I know something on the order of 25 of them.
#139049 - 20/02/2003 11:44
Re: Status Update
Just loop the security cable through the airflow slots at the back.
When an Empeg/RioCar is inserted, you'll also need to loop the cable through the handle on the player.
#139050 - 20/02/2003 12:01
Re: Status Update
What I mean is that I currently have a security cable that attaches to the security slot in the back. (Actually, there's this screw-on nut that attaches to the slot and then the cable attaches to the nut.) I'd like to keep that configuration. Is there space in the dock for it, and is there a hole the cable can go through, or free space to drill such a hole? The whole mechanism, when attached sticks off of the back of the empeg by about an inch and a quarter, which is significantly deeper than the docking connector, at about five-eighths of an inch, so another five-eighths deeper, give or take.
#139051 - 20/02/2003 12:07
Re: Status Update
Actually, it looks like that's exactly where the ethernet connection is going through the back, so I'd have to reroute that. Sigh. Special orders? (Not that I have any cash.)
#139052 - 20/02/2003 12:15
Re: Status Update
I think it would be much much simpler to just obtain another steel cable, with loops on each end. Just thread it through the handle (and rear of the dock if you're really concerned), and loop it around something BIG and HEAVY and lock it with an ordinary lock..
#139053 - 20/02/2003 12:20
Re: Status Update
Too tacky for me.
Part (most?) of the reason I'd want it is to avoid having cables strewn about when I'm not here. Having something like that going on while I am here isn't going to happen.
Edited by wfaulk (20/02/2003 12:22)
#139054 - 21/02/2003 16:08
Re: Status Update
Loc: Denver, Colorado
Being a cheapskate and not wanting to spend $$$ on a cool box (I really need two) when you get tired of making these units up will you come up with a set of plans available with the docking connector with pins (the rest looks like its readily available)?
Edit: I just noticed the sled connectors are available from Digikey (read the parts list thread), so even just making the plans available for a reasonable price would do.
Edited by ADent (21/02/2003 17:50)
#139055 - 24/02/2003 12:38
Re: Status update
Greetings!
I can relate. Is that fix to make the insertion tighter in the first few units? I was just doing "show and tell" at the office for another person with an empeg, and the same exact thing just happened. Unfortunately, mine is not booting at the moment - disk not found errors. I did the first set of troubleshooting (checking connections, jumpers, each drive individually, etc.), but no luck so far. More testing when I get home. The display board and everything else looks good.
To add insult to injury, this is the exact same unit that was just repaired for the dry solder connections. I suspect that some more pins came loose, but I will need a magnifying glass to verify that.
I think, after I get this fixed, that I might retire this unit to the quiet life of a spare... It has been through a lot - dry solder, display cable fraying, stripped space, buttonhack, digital out, multiple hard drive upgrades, etc...
#139056 - 24/02/2003 12:45
Re: Status update
[Re: pgrzelak]
Aw, Paul, my condolences on your loss. Had you adjusted the two screws where the handle clicks in? I tweaked those a little bit to make sure it's in tight.
#139057 - 24/02/2003 12:47
Re: Status update
[Re: tonyc]
In my case, not tightly enough... I will adjust them a bit more.
#139058 - 24/02/2003 12:49
Re: Status update
[Re: pgrzelak]
Well, not that it makes you feel better, but at least you have the wherewithall to solder anything that might be busted. Perish the thought, but if my empeg were to have any such problems, I'd have to send it out to someone with electronics experience beyond the Radio Shack 120-in-one project kit.
#139059 - 24/02/2003 13:21
Re: Status update
[Re: tonyc]
You mean the empeg's innards aren't all connected together with springs?
#139060 - 24/02/2003 13:33
Re: Status update
I honestly think this player would do better with springs! It has been through a lot.
Actually, I am inept with a soldering iron. I usually request or obtain the services of others in order to do this. For example, Mark did my button hack and Stu did my digital out installation and dry solder fix last time. Worst case, I could always attempt it or send it in for servicing.
That is why backups are so important!!! Always back up your data. And redundant hardware is a must if you demand high availability!!!
#139061 - 24/02/2003 14:11
Re: Status update
[Re: pgrzelak]
Ouch! Yeah, as noted earlier in this topic (somewhere), DO NOT TILT THE DOCK WITH A PLAYER INSERTED!
The player's latches are not really designed to support the full weight of the player, but rather to just keep it from casually coming loose when near horizontally inserted into a car's dash.
The two black screws just inside the dock opening can be adjusted to provide more friction to make it safer, but still..
Hope it comes back to life!
#139062 - 24/02/2003 14:51
Re: Status update
heh, i almost did this last week when showing it off to fellow empegers here at work... i had the dock 2 inches off the desk with empeg inserted when i remembered your mishap and quickly set it back down, removed the empeg, and continued the display. =]
#139063 - 24/02/2003 19:11
Re: Status update
[Re: loren]
Well, the drives are okay, but it looks like the IDE header may have lost a bit more solder. I can hear the drives attempt to spin up, but it never gets far enough to autodetect them. So, I will be running on the spare for a little while.
#139064 - 25/02/2003 19:00
Re: Status update
got mine today very nice.gona go hook it up to my b&k right now.Thanks agian.
040103958 60g
#139065 - 26/02/2003 09:56
Re: Status update
[Re: thrasher]
I'm curious what everyone's going to use to cover the unit? I guess paint would be best but I would really like to get a su per glossy black finish. Anyone have ideas? Maybe some sort of enamel? I guess I'll start looking into these things before mine ships
#139066 - 26/02/2003 10:12
Re: Status update
[Re: jcboeckl]
Loc: Swindon, UK
if you find anything please post info/pictures. I'd love to get mine covered in a piano black lacquer type of finish (like nice expense speaker cabinets).
Andy
MK2a 60GB Amber 040103916 32mb/Light Kit
MK2a 50GB Amber 030102560 32mb
#139067 - 26/02/2003 10:30
Re: Status update
[Re: jcboeckl]
Just spray it black with a can of black enamel spray, maybe 2-3 coats for even coverage. Then spray a nice clear laquer finish (or even clear glossy polyurethane) over it all and it will look incredibly glossy.
#139068 - 26/02/2003 10:54
Re: Status update
[Re: skibum]
Loc: Louisiana, USA
Sherwin Williams sells piano black lacquer in gallons . You will probably want to use a primer or sanding sealer compatible with lacquer before proceeding to the lacquer. The surface needs to be absolutely smooth prior to applying the lacquer or the imperfections will show in your finish coats. You will need a spray gun, 8+ coats of lacquer, and will have to rub the finish out multiple times (wait at least a week after the final coat before rubbing out) to achieve the sort of effect you see on pianos and high end speakers. Many finishers use 3M and Meguiar's auto polishing compounds for the rubbing process. I don't know if it is worth it to you or not, but the above is a lot of work.
Stu
#139069 - 27/02/2003 08:14
Re: Status update
[Re: maczrool]
I was just curious how queue numbers can go backwards?
#139070 - 27/02/2003 10:55
Re: Status update
[Re: Neutrino]
Depending on the model you ordered, your position may change radically from time to time, as I will tend to batch-build units of the same type.
ISTR that Mark further clarified this, and that your position within the list of people that ordered the same type will not change.
#139071 - 27/02/2003 11:21
Re: Status update
[Re: genixia]
Doh!! I guess that I just need to learn how to read.
#139072 - 03/03/2003 13:35
Re: Status update
[Re: jcboeckl]
Let's cover them with Formica! ![](/images/icons/smile.gif) Any chance of these being sold as kits to lower build time, shipping (?) and cost?
#139073 - 03/03/2003 13:39
Re: Status update
[Re: SE_Sport_Driver]
Or this. I knew a guy in OK that covered a whole jeep in the stuff...
Michael West
