Page 4 of 5 < 1 2 3 4 5 >
#140458 - 27/10/2004 07:28 Memory upgrades parts list [Re: mdavey]
mdavey
Loc: Wellingborough, UK
Hi,
From the posts in the memory upgrade threads, the critical part for a MK2A memory upgrade is
2 of 4Mx16 3.3v 50ns 4k refresh TSOP-50 EDO DRAM: Micron MT4LC4M16R6TG-5 or equivalent.
For a MK1 and a MK2 respectively, 4 ICs are required.
I *think* the correct parts are:
1Mx16 3.3v 50 or 60ns 1k refresh TSOP-44/50 EDO DROM: Micron MT4LC1M16E5TG-5, Siemens HYB3118165BST-60 or equivalent.
In particular, I'm not sure about the speed - 50ns or 60ns? Is the refresh right?
Michael
Ex-owner of stolen empeg #030102741
#140459 - 27/10/2004 08:21 Re: Memory upgrades parts list [Re: mdavey]
By the way, if anyone needs Mark2A RAM, I still have a bunch of chips left.
#140460 - 05/11/2004 03:43 Re: General Parts list.... [Re: tfabris]
RobotCaleb
did this ever get FAQ'ed?
if so, feel free to unstickify
#140461 - 09/11/2004 02:19 Re: General Parts list.... [Re: RobotCaleb]
More or less.
#140462 - 05/12/2004 21:05 Re: General Parts list.... [Re: tfabris]
Ezekiel
Loc: NH USA
Tony - did the parts list above get FAQ'd? I searched using 'parts list' and didn't get a hit. Is is there? Is my search Fu just that weak?
The changelog seems neglected as well, it reports the last change as July 30, 2002. I assume this is incorrect?
-Zeke
WWFSMD?
#140463 - 06/12/2004 03:43 Re: General Parts list.... [Re: Ezekiel]
Not yet. Sometime I'll get around to doing a really nice format and everything. In the meantime, it's stickied here on the BBS.
#140464 - 06/12/2004 04:45 Re: General Parts list.... [Re: tfabris]
oliver
Quick question, Is this the right fuse
SMD Fuse: FUSE 1.00A 63V 1206 SMD Digikey part WK4661CT-ND
to replace this fuse?
and, would anyone have two spares kicking around they'd like to sell?
Edited by oliver (06/12/2004 04:46)
#140465 - 06/12/2004 07:41 Re: General Parts list.... [Re: oliver]
mdavey
Quick question, Is this the right fuse [part] to replace this fuse [pic]?
Yes.
Where are you? Try Rob Scofield (scofiel): carsupport at xs4all. nl. If you are in the US, there are a number of US BBS members that may be willing to sell you a fuse. In the unlikely event that Rob is out of stock and you don't want to wait, I have a spare (I am in the UK).
Michael
#140466 - 06/12/2004 11:50 Re: General Parts list.... [Re: tfabris]
Ezekiel
Loc: NH USA
The sticky is very much appreciated, btw! Thanks for the update.
-Zeke
WWFSMD?
#140467 - 22/03/2005 23:14 Re: General Parts list.... [Re: Ezekiel]
mrfixit
I found this site and thought I would post it, looks like they might be good leds for the empeg knob... very small and very bright.
http://www.lc-led.com/View/itemNumber/88
Ben
hijacked
#140468 - 02/05/2005 05:23 Re: General Parts list.... [Re: mrfixit]
meast
Anybody ever find a part number for those stepped screws that go into the docking connector on the back of the unit? The connector is really cheap and all, but I'm now buying my third one just to get the screws (which keep falling out).
Cheers.
MEast 40GB MK2a in '04 BMW 330CiC with BSW 300w Amp & 10" Custom Sub
#140469 - 02/05/2005 05:45 Re: General Parts list.... [Re: meast]
SonicSnoop
Loc: Triangle, VA
I dont know the part number for the screws but you might try some locktite on the next ones you install.
#140470 - 13/06/2005 04:19 Re: Memory upgrades parts list [Re: pgrzelak]
Sipho
Loc: Utah & Silicon Valley
I'm interested. What is the price and minimum order quantity?
-- Craig
#140471 - 15/12/2005 10:05 Rear Sled Connector [Re: Sipho]
bad
Loc: Hong Kong
I'd like to make a custom harness with molex connectors to make adding the sled plug n play (as well as putting back my deleted RCA connectors for the tuner).
This is the correct part to go on the sled I believe and I would like to know which are the correct connectors to add in at the back after attaching the wires.
Thanks.
Edited by bad (15/12/2005 10:06)
Empeg MkII Rio MKIIa Long term Empeg user; newbie to the forums !!!
#140472 - 15/12/2005 10:20 Re: Rear Sled Connector [Re: bad]
bad
Loc: Hong Kong
I guess it is this one for everything other than power
Digikey Part No. H10087-ND
#140473 - 15/12/2005 11:29 Re: Rear Sled Connector [Re: bad]
Consult the shiny new Empeg Wiki
#140474 - 15/12/2005 18:20 Re: Rear Sled Connector [Re: JBjorgen]
Nice work!
Maybe we can unsticky this post after someone modifies the FAQ. I'd say that we could use another post or two in the FAQ forum here pointing people at the Wiki for third-party software, the Hijack FAQ, replacement parts, etc., in addition to the normal FAQ.
#140475 - 16/12/2005 18:33 Replacement Parts List [Re: wfaulk]
The Replacement Parts List now resides on the Empeg Wiki.
I'm de-sticky-ing the thread and editing the original post. Tony, could you please update the FAQ and, perhaps, put a thread in the FAQ forum?
#140476 - 17/12/2005 23:38 Re: Replacement Parts List [Re: wfaulk]
I had been meaning to get around to putting the parts list in the FAQ and never did. So I just put an entry in the FAQ linking to the parts list.
#140477 - 12/01/2006 16:40 Re: General Parts list.... [Re: lopan]
IDE Header: 44-pin 2mm spacing, male, surface-mount, Molex #87759-4450, Digikey #WM18669. Also wikkied.
#140478 - 31/01/2006 00:38 Re: General Parts list.... [Re: mlord]
cshuttle43
Sure....but how do I replace the RCA connectors...? I've been looking all over the place for replacement RCA connectors (connectors that just end in tinned wire, and aren't terminated with another RCA connection) and I can't seem to locate them.
I suppose I could clip the ends of existing RCA cables, but I'd like to achieve some semblance of audio quality here. Any pointers would be great.
#140479 - 31/01/2006 01:12 Re: General Parts list.... [Re: cshuttle43]
Radio Shack.
Digikey.com
Frys.
Any other electronic components place.
#140480 - 31/01/2006 02:21 Re: General Parts list.... [Re: mlord]
cshuttle43
I did see them at Radio Shack, but they're male only which would require an adapter. I also took a look at digikey, but they only sell completed adapters, it would appear.
#140481 - 31/01/2006 04:09 Re: General Parts list.... [Re: cshuttle43]
adavidw
Loc: Utah, USA
Something like this?
-Aaron
#140482 - 31/01/2006 13:40 Re: General Parts list.... [Re: adavidw]
cshuttle43
Rock and roll...I get it now; thanks!
#307154 - 11/02/2008 16:37 Re: Tuner Connectors! [Re: maczrool]
Originally Posted By: maczrool
# 1 SMD Transistor: Digikey part MMBT390DICT-ND
I believe that there is a 6 missing in the transistor part number above. It should be MMBT3906DICT-ND
Now discontinued. The RoHS compliant replacement is MMBT3906-FDICT-ND
#326158 - 17/09/2009 18:00 Re: Replacement Parts List [Re: wfaulk]
Sigh.
Restickifying.
#335926 - 09/08/2010 15:10 Re: Replacement Parts List [Re: wfaulk]
Anyone know how to locate and order Mark 2 docking connector parts? Both sled-side and player-side.
Right now I think I might be looking for a couple extra parts of the player-side half of the mark 2 docking connector. Both the plastic bit and the pins.
I recall someone in another thread was inquiring about something similar recently.
#335942 - 09/08/2010 23:06 Re: Replacement Parts List [Re: tfabris]
If they are the same as Mk2A (and I'm pretty sure they are), I still have a bunch of docking connector sled side (only) pieces. Would be fairly economical to post from Australia.
Otherwise Digikey
http://search.digikey.com/scripts/DkSear...Words=H10087-ND
http://search.digikey.com/scripts/DkSear...Words=H10086-ND
(for the sled parts at least)
See also down below for "related" parts.
#335979 - 10/08/2010 18:28 Re: Replacement Parts List [Re: Shonky]
Thanks, but my main desire is for the Mk2/Mk2a player-side bits for now. The big black plastic piece as well as the little pins.
