#140871 - 06/02/2003 15:31 sorry about this..... sendmail configuration
I'm trying to get the mail() function in PHP to work on my sparc, I had a quick look at the php.ini file and saw that SMTP only seems to be supported on win32, if you're running unix is seems you need to use sendmail. Problem is I haven't got I fscking clue how to configure it, the documentation seems to be rather cryptic. All I want it to do if relay everything through to my ISPs smtp server. HELP!!!
Running Debian 3.0 "Woody" BTW...
#140872 - 06/02/2003 15:35 Re: sorry about this..... sendmail configuration [Re: andym]
You're interested in the ``smarthost'' option.
If you're lucky, all you might have to do is edit your as-distributed sendmail.cf and add the line:
DSmail.isp.net
Search to see if a `DS' line already exists.
#140873 - 06/02/2003 15:44 Re: sorry about this..... sendmail configuration [Re: andym]
If you've got Debian installed, you'll probably have exim installed. If you run 'eximconfig', it'll let you configure your box as a 'satellite' system (option 3).
The 'sendmail' that PHP wants to use (/usr/lib/sendmail) is actually a symlink to /usr/sbin/exim, which should do the right thing.
#140874 - 06/02/2003 16:10 Re: sorry about this..... sendmail configuration [Re: Roger]
Ah...I run redhat 7.2 and was having a similar problem. I had it setup correctly in the php.ini according to the documentation, but none of my mail functions in PHP worked. I finally tired of it and hacked together a couple functions to parse headers and recipients and send mail and packaged it up as a php include file. It works quite well. Let me know if you need it.
EDIT: nope...not the same problem...my box is it's own smtp server...doesn't run through the ISP's
EDIT again: Here is that .inc file. To be honest, I snagged it from somewhere else on the net and modified it to meet my own needs, so I can't take credit for it. It does work quite well.
#140875 - 06/02/2003 17:22 Re: sorry about this..... sendmail configuration [Re: JBjorgen]
That's lovely, thanks guys, I've managed to send a couple of emails already. Nice one ....
