#140887 - 06/02/2003 16:50 Can this be done
thinfourth2
Okay i have an empeg with hijack running, I have an ethernet card, i have a modem is it posible for someone to view the contents of my empeg over the internet.
If so how the hell would i do it.
#140888 - 06/02/2003 16:52 Re: Can this be done [Re: thinfourth2]
Daria
are the ethernet card and modem attached to a pc? basically you either need the modem to be attached to something doing connection sharing and port remapping.
#140889 - 06/02/2003 16:53 Re: Can this be done [Re: Daria]
yup...look around for port forwarding. I think it may be built in to some versions of Win2k
EDIT: argh...I'm redundant yet again.
#140890 - 06/02/2003 16:54 Re: Can this be done [Re: JBjorgen]
Daria
#140891 - 06/02/2003 17:01 Re: Can this be done [Re: Daria]
thinfourth2
Oh yeah forgot that pc thing connecting the whole lot together which runs win2k and i have winroute lite running on it and have a freebie version of winroute pro hanging around as well
whole lot is connected to a network hub, empeg haveing a fixed IP to make it easier to connect to it with a crossover cable when it is off on travels the laptop on a wireless connection to make it easier to surf the web from anywhere it getting an address from PC on desk
If that makes things clearer
#140892 - 06/02/2003 17:07 Re: Can this be done [Re: thinfourth2]
Yes, it can be done (as was said by others in this thread).
But, to paraphrase Ian Malcolm...
The people on this thread were so concerned with answering whether or not you could, they didn't stop to give you advice on if you should.
I have serious reservations about seeing Thinfourth put ICS on his PC:
- ICS is a piece of crap software implementation that I've personally seen screw up the network configuration of more than one PC.
- Exposing the empeg to the internet is dangerous, because by default it has no network protection on it. People could delete tunes, erase the hard disk, etc., all without a password.
Sure, both of the above can be worked around and dealt with by someone who's very good with these sorts of things, someone who knows how to lock down the empeg and to troubleshoot the inevitable problems with installing ICS. But while I'd trust Thinfourth with my life if I needed the Diesel engine on my oil tanker repaired, I'm not so sure he's the right guy to be plunging alone into the world of Microsoft's Buggy and Badly Implemented Connection Sharing Software.
#140893 - 06/02/2003 17:09 Re: Can this be done [Re: thinfourth2]
Okay, well, that changes everything. Since you're already mucking with this stuff, then be my guest!
And more power to you, that you're not using Microsoft ICS.
#140894 - 06/02/2003 17:19 Re: Can this be done [Re: tfabris]
thinfourth2
I tryed ICS and was amased at how quickly my network stopped working it wa like attacking the cables with wire cutters. i was shown winroute by someone on this board and was impressed
As to doing this i am just pissing around and want to learn more so if i can do it great another little bit of knowledge gained from the board, one cannot live by diesel alone
Yes it probably is a bad idea but still want to know more
#140895 - 06/02/2003 17:21 Re: Can this be done [Re: thinfourth2]
Yup. My experience, too, and it was the reason I suggested that you don't use it.
#140896 - 06/02/2003 19:47 Re: Can this be done [Re: thinfourth2]
As a BRIEF demonstration:
http://rtr.ca:8086/?FID=101&EXT=.htm
Note: this link will cease to function sometime on 7-Feb-2003,
so please don't bug my firewall after that.
Also, the bandwidth (in theory at least) is limited,
so you probably cannot successfully stream music from it..
EDIT: URL repaired after BBS code tried to mangle it..
Edited by mlord (06/02/2003 19:58)
#140897 - 06/02/2003 19:49 Re: Can this be done [Re: mlord]
Daria
403 Access Not Permitted
GET /
#140898 - 06/02/2003 19:53 Re: Can this be done *DELETED* [Re: Daria]
Post deleted by mlord
#140899 - 06/02/2003 19:53 Re: Can this be done [Re: Daria]
The link is wrong. It should be "http://rtr.ca:8086/?FID=101&EXT=.htm" instead of "http://rtr.ca:8086/?FID=101&EXT=.htm<pre"
- Trevor
#140900 - 06/02/2003 19:57 Re: Can this be done [Re: tman]
Ahh.. silly BBS tried to rewrite my URL, even though it was within a "pre" formatted tags.
#140901 - 06/02/2003 19:57 Re: Can this be done [Re: mlord]
Daria
It works now.
#140902 - 06/02/2003 19:59 Re: Can this be done [Re: mlord]
Daria
<pre> tags don't get honored.
#140903 - 06/02/2003 20:24 Re: Can this be done [Re: Daria]
Oh, by the way..
That's a "docked" empeg, one of my backup units in the new dock. I guess the ethernet connection is working, huh.
#140904 - 06/02/2003 20:31 Re: Can this be done [Re: mlord]
Daria
You could be running ppp
#140905 - 06/02/2003 23:48 Re: Can this be done [Re: tfabris]
TheAmigo
ICS does lack usefull documentation, but if you know the behind-the-scenes of what it's doing, it works quite well. I've configured it many times for co-workers to have to travel with their laptops and demo software by allowing customers to share their network connections.
ICS pretty much turns your PC into something like a Linksys Cable/DSL router: enables NAT and a DHCP server and forces your IP address to be 192.168.0.1 (hence dropping off the LAN).
--The Amigo
#140906 - 07/02/2003 09:17 Re: Can this be done [Re: TheAmigo]
suomi35
Loc: Los Angeles, CA
I used to do this. Forwarded port 3535 into port 80 (on the empeg) on my internal LAN via iptables (linux). Never had any problems.
-Jason
#140907 - 07/02/2003 10:30 Re: Can this be done [Re: TheAmigo]
lopan
Loc: Manassas VA
I think ICS would be great... if it didn't force the 192.168.0.1 IP.... what if I want to actually configure something other then that? For this single reason it makes it absolutely useless to me.
Brett 60Gb MK2a with Led's
