#141248 - 08/02/2003 19:13 Hard Wiring the Sub Output: Combinding Grounds?
DirtyDozen
Loc: ... they call us Massholes
I need to hard wire the Sub Outputs through the harnesss loom.
The thing is I only have three pinouts that I can sacrifice:
Pin #2 - amp. remote
Pin #12 - microphone sleeve
Pin #24 - microphone tip
I would need two for R+, and L+...
Would it be a bad idea combining the two negatives together?
(The other two sets of audio outputs have the grounds combine...)
(... regards to all.) [orange]- DirtyDozen[/orange]
#141249 - 08/02/2003 22:09 Re: Hard Wiring the Sub Output: Combinding Grounds [Re: DirtyDozen]
genixia
*Ideally* you'd want the sub grounds to be exactly the same as the other output grounds - so splicing into the loom would achieve this. If you didn't do this then there might be some potential for a ground loop. However, without knowing what the sub board schematic is, I can't say for sure. I would expect that Maczool has done a good design job on the board and that the sub out ground is distinct from the digital ground but you should check.
